FI engine tolerances??
Old 10-16-2007, 01:47 PM
TN94Z's Avatar
Default FI engine tolerances??
Where can I find engine tolerances for a FI build?
Old 10-16-2007, 08:48 PM
DeltaT's Avatar
It's really just ring tolerances. Check with your preferred ring mfg. Federal Mogul makes Hellfire rings for FI, and they have a chart based on use and boost, nitrous, whatever you want.
Jim
Old 10-16-2007, 09:19 PM
99mongooSS's Avatar
the rings just need to be low tension rings, right?
Old 10-17-2007, 07:30 AM
TN94Z's Avatar
Thanks. I just wanted to make sure.
Old 10-17-2007, 03:12 PM
Firechikn's Avatar
Piston to wall tolerances will change also. Your pistons should have a spec card telling you what it should be. I know the Diamond race pistons require a lot of clearance for a max effort engine.
Old 10-17-2007, 07:48 PM
helicoil's Avatar
Default Rings
I would not recommend low tenision rings for a forced induction max effort engine. Keeping oil out of the combustion chamber should be more of priority than picking up 3% HP from low tension oil ring expanders.
Old 10-17-2007, 10:04 PM
99mongooSS's Avatar
i didnt know thats just what someone said I wanted to check.
Quick Reply: FI engine tolerances??
