Generation IV Internal Engine - push rods
blackbyrd
10-18-2007, 01:34 PM
im trying to figure out push rod length
l92 heads with factory rockers on .620ish lift
thought about getting a length measurer but i figured i would ask before i got one and screwed up the measurements
bg-sdpc
10-18-2007, 06:22 PM
L92 heads will not require a pushrod length change. 7.400" is what we use in all of ours.
Brian
blackbyrd
10-24-2007, 07:07 AM
even if the heads are on a 6.0 L iron block??
bg-sdpc
10-24-2007, 08:54 AM
Yes because all of these engines have the same deck height with the exception of the LSX block.
Brian
blackbyrd
10-24-2007, 12:11 PM
cool was unsure of that
thanks again
95FbFormula
10-24-2007, 07:04 PM
Wouldn't you still have to use a different PR size if the heads have been milled say to 65cc. also what is the standard deck hi=eight the ls1/2-lQ9 iron blocks
TKO52
06-30-2008, 08:58 PM
same question i have i am going to mill my heads .030 to retain stock cr worried that i will have to buy new push rods
Big Bird WS6
07-01-2008, 10:16 AM
talking about push rods. i need a stock lenght set with a smaller oil hole? any one know where to get them?
Big Bird WS6
You can get pushrods with restrictor holes through Smith Pushrods. I use them in my race car.
MSUGTP
07-01-2008, 11:34 AM
If the heads are milled, couldn't you subtract the amount you milled your heads from the pushrod length (7.400") to get the pushrod length that you need for your particular application?
Randy WS6
07-01-2008, 09:04 PM
If you shave the heads or change thickness in head gaskets or even have a valve job were they cut the seats moving the valve stem closer to the rocker, you need to check the pushrod length, so you don't collapse a lifter, But if every thing is stock height i just go stock length, But thats just me.
White_Hawk
07-02-2008, 09:46 AM
Aftermarket cams have a smaller base circle too. I wouldn't think of buying pushrods before measuring if you have an aftermarket cam and milled heads.
-Geoff
TKO52
07-03-2008, 03:30 PM
found some help here on this topic
http://forums.corvetteforum.com/showthread.php?t=1685795
This good link for checking the proper length
http://www.ls1tech.com/forums/showthread.php?t=637575
89Formulaws6
07-04-2008, 11:58 AM
stock heads stock gm headgasket 7.400 pushrods with around same lift cam
vBulletin® v3.7.4, Copyright ©2000-2013, Jelsoft Enterprises Ltd.
Search Engine Optimization by
vBSEO 3.5.2
