4.30's in 00' T/A M6
Only mods being lid and cut-outs, If I put 4.30's what would I run? its a 00' trans am with 80k, 6-speed on stock 10 bolt. using street tires. Would it drop me a .5 atleast. I dont want to run stickys, no cash if I break stock rear. what should I expect?
To answer your ???? most likely not on street tires,first gear will be useless. The street tires will not give you any where close to enough traction to get a good 60' to reduce your time .5 you may end up with a higher mph.But hey you never know it could improve you times a little and make your car a blast to drive.It would be a totally different beast than you stock gears.
