Drag Racing Tech
Will this roll cage certify?
Old 10-18-2007, 03:19 PM
Z06kern's Avatar
Default Will this roll cage certify?
I bought a car with wolfe thur the floor sub frame connectors. The cage is welded to 2" x 3" mild steel outriggers. All the pictures I have show the hoops welded to 6x6 plates. Thanks!
Old 10-18-2007, 05:03 PM
T Pizzle's Avatar
Should not be a Problem
Old 10-18-2007, 05:26 PM
chrismorales75's Avatar
That looks fine to pass cert.
Old 10-18-2007, 05:41 PM
Ari G's Avatar
Do you have to have a welding master cert to have the welds cert?
Old 10-18-2007, 05:50 PM
HAMRHEAD's Avatar
What do they look for to certify the cage? Any tests performed?
Old 10-18-2007, 06:18 PM
scott94z's Avatar
i think they sonic test, not sure. I'm getting ready to build mine too
Old 10-18-2007, 11:20 PM
Sonic test for minimum .118 wall thickness for mild steel .083 for c-moly I think, look for weld quality and to make sure you have the right amount of points and that the cage is welded to 6x6 plates or to sub frames. The cage in the photos should certify fine.
Old 10-19-2007, 08:05 AM
85Iroc's Avatar
If I have bars going thru the floor, closer to the tunnel, that connect to the ladder bar crossmember, which connects to the subframes, would the main hoop still HAVE to have 6x6 plates or would maybe a 4 or 5" square plate be ok. I think I know the answer but that part of the cage was installed before I thought about certification several years ago.
Old 10-19-2007, 08:24 AM
Z06kern's Avatar
Thanks, now I just need to find someone to certify it.
Old 10-19-2007, 08:35 AM
10 Second Moderator
Torkman15's Avatar
I wouldnt certify it till you need it certified. Are you planning on going faster than 9.99 right outta the box? If not i'd save the money till you need it because a cert is only good for two years.
Old 10-19-2007, 10:56 AM
kp
kp's Avatar
The 75.00 is well worth it to get it certified, especially if you sell the car or plan on hitting some bigger events. They will check the tube diameters with a go/no-go gauge, sonic test the tubing, look at the welds (they have to be extremely shittty to not pass) and make sure all the points are there. Usually at the beginning of the season most local NHRA tracks have a day where they do chassis inspections right at the track.
Cert is good for three years on sportsman cages.
Old 10-19-2007, 12:10 PM
It's best to make outriggers from subframes to the rocker panel and you won't need plates. If the main cage isn't welded to the frame or outrigger it must be welded to a 6"x6" plate 1/8" thick.
Old 10-19-2007, 01:46 PM
Z06kern's Avatar
Good info in this thread. Thanks!
Old 10-19-2007, 05:33 PM
cbrrmike's Avatar
for the cert, after 3 years can you just go back and recert the same cage or do you have to have anything done to it to recert?
Old 10-19-2007, 06:46 PM
TheOutlaw1's Avatar
Did you MIG weld the bars and are the bars mild steel or chromemoly?
Old 10-19-2007, 07:27 PM
kp
kp's Avatar
If they dont change the rules then you dont have to change anything.
Old 10-19-2007, 11:30 PM
You just recert the cage when it expires.
Old 10-21-2007, 10:14 PM
Z06kern's Avatar
The bars are moly and I TIG welded all of them.
Quick Reply: Will this roll cage certify?
