Rearend Problem??
Rearend Problem??
Could this be a problem with the rear end?
https://ls1tech.com/forums/lt1-lt4-modifications/800924-drivetrain-problem.html
Well i replaced the rear shocks a few months ago and everything else looked fine. The car came with aftermarket LCA's. Everything looks fine on the outside and the car runs great. Just every time car is given more than half throttle at low speeds (15mph and lower) this vibration comes out of no where. I think the only reason the tranny mount helped was because it is a high mileage car and that added a little extra cushion.
Maybe i would be better off asking what the symptoms of a rear end on the verge of going out are.
