Single Turbo question for my 67 camaro
I am thinking about building a single turbo motor on my 67 camaro build. I found some turbo headers for it and was wondering if the size was ok. The header and turbo flange are 3/8" thick and the primary tubes are 1 5/8". 321 stainless steel headers. What do you all think?
TIA
TIA
Yeah, yeah, sorry guys. It was late when I posted that and wasn`t thinking. It`s a gen1 sbc 383. I have no turbo yet and don`t even begin to know what size and what not to buy. The motor will have the Holley ramjet fi setup as well. I`m not looking for huge numbers. Maybe 650hp at the rear wheels max. What do you think?
15psi? that much huh? shows how much I know about turbos. I plan to run a roller cam setup. I want power brakes, so I`ll need good low idle vacuum for sure. I don`t need a huge cam, but something nice. I was thinking about AFR heads. What size? Thanks guys
If the engine truly makes 400hp at the wheels right now, maybe only 10-12psi to achieve those numbers relatively easy. With a turbo, you don't need a huge cam... maybe something in the 23x/24x range with a 114-115LSA. Don't know much about the AFR heads for gen 1's, but you could run something in the 220cc intake size, with large chambers...
This is a street car. Not a race car. I would like to have as much low rpm power as possible. I don`t that I would want to go as big on everything as your mentioning.
Go check out the GM section on turbomustangs.com Just do a lot of searching. There are a bunch of first gen Camaros with turbo SBCs in them over there. Lots and lots of really good info over there. Just make sure you register and search a lot before asking any questions. There are brutal over there if you ask a question that has been answered dozens of times already.
