Gears & Axles - 9 inch 3 channel done!!!
View Full Version : 9 inch 3 channel done!!!
ssvert99
10-19-2007, 09:17 AM
I have the 9 inch 3 channel abs working on the prototype finally! It uses the stock 10 bolt sensor and will be available in the new Midwest Chassis & Performance, Inc. fabricated housings. I still have a little r&d to do, but theres no reason this won't be available in the next week or so. It is setup in a Strange iron case and a Truetrac diff, which is the most popular setup.
The torque arm on my rearends is available in both solid and poly bushed front mounts which solves most of the noise associated with tunnel mounted arms.
The torque arms are made from 1-1/4 chromemoly tubing and have no bends in the bottom tube which creates a potential weak spot for the cars with a lot of power. It is adjustable at all ends and feature Aurora heim joints. Both tunnel mount and trans xmember mount torque arms are available and part of the fab housing package.
I'm not going to post any pics of the 3 channel abs setup, as this is a first in the industry.
chino_man279
10-19-2007, 02:56 PM
Excellent, someone that is finally taking a chance at mass producing the setup. You are far from the first one in getting this to work...Have had it running in the 9 inch for 6 years now. It too uses the stock 10 bolt sensor. I am sure others have had it running way longer than this.
All this aside I am interested in seeing how you did it. Post up some pictures. I am looking to purchase another 9 inch before next summer. Hopefully you are fully up and running with mass production of them by then.
fastlt1
10-19-2007, 03:35 PM
Will it work with a spool?
donkey mule
10-19-2007, 07:46 PM
How much and what will the turn around be?
ssvert99
10-20-2007, 09:47 AM
i'm sure other people have done it, but not to offer them to the public as an option on a rearend.
i have not checked the clearances on a spool. chances are that someone thats using a spool will have the abs deleted from the car already. thats why i am testing with a truetrac. not that it can't be done, but i haven't tried yet. i have a old used moser spool here, and a new Strange. i will try in the near future to see, but the truetrac is the one for now.
cost will be around 100-150 as an option on the new rearends, same as the 4 channel. if you want one mounted in a used stock type housing , it will be more.
_JB_
10-20-2007, 02:48 PM
Maybe I will get a 9" over the S60 now. Subscribing...
93TAWicked1
10-21-2007, 01:23 PM
So sorry if this is a stupid question, but if I bought a new housing could I just use everything elsefrom my current Moser Driveline solutions setup?? Is it easy to put together?
Thanks look forward to this!! Now if I can stop the TA bracket slamming into the floor this will be the perfect rear!
wrd1972
10-25-2007, 06:45 PM
How is this project progressing. I am very interested in some information on this ASAP.
ssvert99
10-25-2007, 10:28 PM
its all done, just have to get a few housings setup for it. 3 channel abs will all be on a per housing order, but the parts are in stock. build time will not be any longer than anything else. i should be able to ship out assemblies within a few days of recieving an order. if you currently have a 9 inch setup, all the parts will(should) transfer to my housings. if you have a 3 channel setup, the center section will have to be sent to me to be retrofitted.
Sharpe
10-25-2007, 11:18 PM
So, if a guy has an F-Body and wants a complete package to switch over to a 9-inch in his back yard, what all parts come in it and how much does it cost? Thanks. :)
ssvert99
10-25-2007, 11:37 PM
its a complete package or parts, whatever you want. base package is a real fabricated housing with drain and multi-hole lca brackets, housing mounted torque arm, trans or tunnel mount front crossmember w/ adjustable torque arm link and driveshaft loop, 31 spline axles, Strange nodular case w/ posi and gear of choice. the base price is 2400.00 for the package and there's many options available, such as 3 or 4 channel abs, truetrac diff, etc. and its all bolt-in.
Scott@DrivelineSolutions
10-26-2007, 12:22 AM
What kind of milling machine are you using to clamp a Ford 9 inch case and drill a hole for a stock sensor with a 8.8 ABS ring?
BTW, do you do 25.5 cages? Looked at your site and seen a chassis car in the background, I'm looking for really clean install. Car is a 1986 Camaro with T-tops, I know but I've gone 8.90's without any glass breakage...
ssvert99
10-26-2007, 09:37 AM
no milling needed. i do have a Bridgeport, but it's not used for this operation.
yea, i do 25.5, 25.2, 25.1E, whatever.
look in the midwest members area. i posted some pics of a cage in a t-top 4th gen car there. it's as clean, well-fitting, professionally welded as you're gonna get. i custom bend everything to the car. no universal fit stuff here. and best of all.... it's affordable!
BIG_MIKE2005
10-26-2007, 10:03 AM
PM sent on cage. Man you could corner the market on this stuff with your great pricing & all the different fab work your capable of.
JWS6
10-26-2007, 10:47 AM
Just talked to Eric. Seems like he knows his stuff and is a stand up guy. Good luck with getting some orders.
RooRnZ28
10-26-2007, 08:50 PM
if this works out well, you will be rich
wrd1972
10-26-2007, 09:21 PM
Yup, I am already selling crap and scraping up the bucks.
10-27-2007, 01:17 AM
PM me a price with a mini tub and 2 Kirkey seats with a 25.5 please. I know Stenod is local for me but I haven't been able to get a hold of them.
TwoFast4Lv
10-27-2007, 01:55 AM
Sure I finally pull the ABS out of my car and you go and do this!
PONYEATER
10-27-2007, 07:56 AM
Ellis,
I am sure if you call and him and talk to him nicely and name drop a little you can get him to cut you a deal ;)
ssvert99
11-02-2007, 10:55 AM
well, somebody finally has to offer it! there are more than just race only guys out there. best thing is... all of these products are derived from tube chassis rearend technology. it works just as well in racecars or street cars. i just figured out the way to eliminate most of the noise.
ssvert99
11-12-2007, 10:03 AM
3 channel ABS for the 93-97 and 98-02 available. this includes a housing and center section modification. as of now, the truetrac diff is the only one it's available with. r&d coming on others.
