New Diamond LT1 Turbo Pistons arrive ...
http://www.taekwondoplus.org/z28/Tur...rbopistons.htm
One step closer! I dropped the box off to the machinists yesterday. He has started converting the bare block to the 4 bolt splayed caps, line boring the mains, boring/honing the block to 4.030" and file fitting the Total Seal AP series rings. The shortblock should be ready for pickup in a couple of weeks.
Good to see a Turbo LT1 build up. Ill have to keep an eye on this post.
Ive got a buddy thats wanting to switch from a ATI to a turbo. definately want to see how yours turns out.
Good luck
Good luck
Thanks Brian! Yes! I've had a run of uncharacteristic (for me) good luck getting all the hardware. I still have to get some coldside piping/couplers to connect the T76 outlet/Intercooler/Throttle body and a BOV. I've been planning on the Turbosmart Megasonic at $250 ish but I'm really wondering if some of the one's I've seen elsewhere for $99 would work. I know you'd said Tiff found one/some that was/were inexpensive but not up to par. I want to do it once and do it right.
