mac oryp
Old 06-10-2003, 07:58 PM
Bradygoodz's Avatar
Default mac oryp
I put on the mac oryp and i have clearence probs between the pipe and the floorboard on the drivers side. At about 3500 rpm it starts vibrating real bad how do I fix.
Old 06-10-2003, 08:00 PM
Bradygoodz's Avatar
Default Re: mac oryp
I also have a damn squeaking noise i cant find from the install too.
Old 06-11-2003, 02:59 AM
malibu350's Avatar
A few people have posted on here that they adjusted the Y-Pipe so that it was as close to the floor board as they could get it and then cut some heater hose and wedged it between there...at the time I tried mine I didn't have any heater hose...so I tried fuel line and it worked...but I didn't have it in there good enough and it fell out...I also read where some people changed out there motor and tranny mounts for poly mounts...and it helped out a lot too...I'm going to be swapping mine out in about two weeks..I will post if it helps at all.....
Old 06-11-2003, 12:45 PM
TaTommyWS6's Avatar
With the ball flanges on the Mac headers and Y-pipe, there is a lot of room for adjustment... Did you try loosening everything a bit, pry the pipes down, then re-tighten?
My Mac ORP has lots of clearance....
Tommy
Old 06-11-2003, 01:28 PM
1MEANSS's Avatar
Mine went in fine, no sqeeks,no nothin????
Old 06-11-2003, 03:52 PM
SSactionLs1's Avatar
its very adjustable...just play with it a bit
Quick Reply: mac oryp
