Launching Technique
Launching Technique
I was wondering if it would be better to launch at 0 rpms or revving to 2500 and slipping the clutch? i dont see the advantage of revving it, then again i am a beginner, i am on street tires and fresh off a cam install and underdrive pulleys. Can someone please explain the "slip the clutch" method to a beginner please
try it both ways.. depending on your setup and the track, both have advantages.. go to test and tune at the track and play with your launch and tire pressure, to find what works best.. good luck
No what is worse than that is to see people run like 5 psi on a 26x10.5 then spin like crazy and think they are making **** loads on power with their 300 hp car.
Worse than that is FWD import cars on stock radials with like 15 psi like it is going to hook like a slick aired down
