slave cylinder leak please helppppp
ok i just changed my clutch to a spec 3+
i changed my slave cylinder like 2 month ago and i had a spec 2 + clutch in it
so i changed the throw out bearing and i put the spacers but when the car is off and i bleed the clutch its fine i get presure on the peddel and theres is no leak but as soon as i turn the car on it starts leakin
i checked the hose and its fine and i checked the bleeding screw and that was fine so im just think what can it be its either i didnt put the throw out bearing on right or my slave cylinder went again
note... it did not leak prior to this install
