WTB: oil cooler line fitting
im in despirate need of the factory sandwich plate that fastens to the block for the oil cooler lines. for a 94 Z with lt1.
the guy at the machine shop lost it , and the part is discontinued from the dealer, and i cant find it anywhere at any auto parts store.
so if anyone has an extra plate laying around that they dont need.
let me know. we can work somthing out.
oh and also the rear seal plate that bolts to the back of the block, that retains the rear seal. i also need one of those also.
thanks alot
aaron
thanks alot
aaron
LSxGuy widda 9sec Mustang
There were two parts to it, the upper that has two bolts to the block and the lower cooler part that screws to the upper portion (like an oil filter) and has two coolant lines going to it. I probably have both, I'll know in a few after I leave work.
I grew up a bit further north, in the Wilkes-Barre area and went to school in Berwick. TastyKakes and Middlesworth chips are two things I can't get here.
Edit: Have the cooler plate and lines, also found a rear seal housing.
