Gears & Axles - Tranction Control?
araber89
10-23-2007, 08:20 PM
I'm getting a 99 Trans Am and the guy who i'm buying from converted it to a ram air and the car doesn't have a traction control button. that being said when i take off will it be pushing with one or two wheels? Like my S-10 only does one wheeled burnouts (weak). i was wondering what it will e on this car because our other dodge 1500 also only has one wheel pushing. i think the car has too much power for only wheel to be pushing on take off.
INMY01TA
10-23-2007, 08:38 PM
Should use both wheels. All these cars have posi rear ends, nothing to do with traction control. Fwiw, I ordered my car with tc and hate it now. One option I wish I didn't get.
Jays00ss
10-23-2007, 08:40 PM
It all depends if you have a limited slip differential or not. Traction contol useses the brakeing system to help with traction.
araber89
10-23-2007, 08:44 PM
Ok so what is the difference in posi trac and trac control? i kno i sould like an idiot to many but i would like to know...
Jays00ss
10-23-2007, 08:49 PM
Posi traction is in your gearing system (in the pumpkin of your rear end) it distributes power to both sides of your axles through a "Clutch" type of system. When one side slips, your other wheel takes over. Traction control works through your ABS and braking system. When the abs sensor senses a slip on one side, it uses your brakes to minimize the slip.
araber89
10-23-2007, 08:54 PM
So even if i don't have trac-control i should still have posi-trac
Jays00ss
10-23-2007, 08:57 PM
Yes, Like the other guy said. I think all ls1 cars come with posi traction. I am no expert however. I am more of an old school muscle guy.
demo3k
10-23-2007, 09:12 PM
Yes like has been said a few times already, traction control and posi are not the same thing. Your car will have posi (both wheels "pushing") even if it doesn't have traction control. My car has traction control and it's damn annoying that I always forget to turn it off when I need to, wish I didn't have it either.
Jays00ss
10-23-2007, 09:18 PM
ya an option you really do not need. + if you take it to the track and forget to turn it off, you'll look like a complete moron. (Haven't done it yet personally but have seen others)
araber89
10-23-2007, 09:20 PM
Alright thanks guys
hazard2k
10-23-2007, 09:53 PM
the option code for limited slip is G80 in most GM cars FYI...
vBulletin® v3.7.4, Copyright ©2000-2013, Jelsoft Enterprises Ltd.
Search Engine Optimization by
vBSEO 3.5.2
