TSB on 04 GTO tire wear
What do I do for the TSB for the GTO so the tires don't rub on the strut mount. Is it something the dealership will fix for free?
Last weekend I rotated my tires to check out said problem and noted the labels were rubbed and the strut was showing a bit of wear. Tires were OK.
So I took mine in yesterday for an alignment, called 5 local dealerships (prior) in the Southeast Michigan area and none of the service rep's know of anything.
Given there are parameters or + & - factors I asked the alignment guy to tip the tires away from the strut.
