New LS1 Owners - Newbie Tech - changing from regular oil to synthetic
z28jjs80
10-24-2007, 09:16 PM
I have a 1998 z28 with almost 100,000 miles. I want to change from regular motor oil to synthetic. What is the correct way to convert to synthetic motor oil?
ghardester
10-24-2007, 09:30 PM
Just do a normal oil change, that's it. I think it's a myth that you can't change after so many miles. Motors with looser tolerances than the LS1 might have oil leak issues but I don't think you will. There are wide opinions on oil types and such, try looking in the General Maintenance section. And I mean strong OPINIONS! Mine is that you can't hurt anything by changing your oil.
Sunset'01Z
10-24-2007, 10:22 PM
go for it.
i run Castrol Syntec 0w30 german formula, wouldnt go with anything else.
CAMAROZ28SS
10-24-2007, 11:48 PM
just do a normal oil change
i use mobile 1 synthetic
Mr Incredible
10-25-2007, 07:44 AM
No issues. No problems.
Just do it.
RPM WS6
10-25-2007, 08:14 AM
Do it...do it. :)
SHINER
10-25-2007, 12:52 PM
Dont just switch all the sudden like that.
Next oil change put a synthetic blend, then after that put a full synthetic.
I recommend Pennzoil Platinum or Valvoline Synpower. They may not have the reputation like Castrol or Mobil but the oil analysis paired it pretty damn close to AMSoil.
NDFORSPD
10-25-2007, 01:18 PM
never heard of goin to a blend first? As long as your engine isnt consuming dino oil regularly(synthetic might amplify the affects)....your good to go, open the cap and pour her in!
LS1ne
10-28-2007, 06:00 PM
use royal purple:D
Detoxx03
10-28-2007, 08:59 PM
Just do it and have it your way.
My1st Truck
10-28-2007, 09:16 PM
I use Amsoil 10W30
I swapped to Castrol 10W40 in my 89 Big Block, nice smooth and quiet.
even with 90,000 miles.
