thoughts on the TU3 for a 408 / PT88
what are your thoughts for a TU3 240/240 .588/.588 112 stuffed inside a 408 9.1 cr, P/P 317s, Ls2 intake, PT88, 4" DP mated to a T56. would like to keep some lope to my setup along with having a decent power range.
3500-7k is diesierd goal with 9xx/9xx to the wheels
with only a t4 flanged pte88 and a 408 i dont think you would make it to 7000rpm, maybe 6200-6500
i have 347 cubes and it spools to 15lbs at 3800-4000 rpm, so your power band starting at 3500 is reasonable. with my cubes and turbo it wants to be spun past 7500rpm though, but i only have taken it to 7200 because of my 42 lb ijectors, that i replaced with 96lbers now.
say on my 6L i could run 23# boost and guess my backpressure is around 40.
since the 408 pumps more air on its own the turbo will only be able to supply maybe 19#. if his backpressure happens to be worse because of the cubes like worse than 2:1; he will still end up only around 40.. which is working totally fine for me and i dont think a 'problem'
additionally it will help if he can bring the revs down..
w/ the t4, smaller cam, and the bigger cubes it will make for one nasty combo as far as boost response and still make the 900 on the tires he is looking for
make sense or no?
Did you measure 40psi backpressure with 23psi boost? If so that's better than what I would expect.
The only reason I say that I would be concerned is we've ran 408's with single 76's with R-trim wheels and 1.15 housing and power/rpm was lower than the identical combination with 370ci.
Now I havn't ran a T4 PT88 to know how it compares in terms of backpressure but with 400+ci I would prefer to run twin T4's or a single T6.
If I remember the setup that was mentioned above correctly it was using a 4" exhaust that was turned down before the rear axle with a Borla bullet muffler which is straight through design.
As for the headers they were 1 3/4 primaries with 2.75" Y's merging at the turbo. I know the same car has now a full thumper 91 and is switching again to the new thumper's we are coming out with, so that will be 4 turbos and data from all four. Let me see if Jose can get the data on the 91.
Parish on his 408 ran a pt88 i do believe and made 1011rwhp/1090rwtq at 25#
i was going to run a single 4" back and have it dumped out the side. no muffler
to keep rev's down i would have to change my gearing which wont be a problem if thats what i have to do.
as for the TU2, would you have any charts of it with power or any clips of it? you guys are the proven ones so If you guys say its to large then time to listen
it was figured i could do 130 @ 7k with the 488s. so maybe ill keep eye open for some 410s. those i think would allow for 150 i believe. i just havent seen any trucks trapping anything higher then 130-135.
