Back motor plate for LS1
Just wondering how you would connect a trans to a LS1 using the motor plate that goes behing the enigne on some high horspower engines. Due to the 1/2 clearance caused by the motor plate
That's called a midplate and they are not 1/2 thick. Contact thunderracing.com, I know madman makes one.
http://www.thunderracing.com/catalog...id=166&sid=750
I know some guys run a rod from the frame to the stock motor mount location or a close by bolt hole to limit forward/rearward movement.
