Do any one else's pedal squeak??
Old 10-26-2007, 09:59 AM
FNQUIKWS6's Avatar
Default Do any one else's pedal squeak??
My clutch pedal just started squeaking when i press it down to shift.
Does your pedal do this?
I dont know why but it really bothers me
Old 10-26-2007, 10:09 AM
8a8mfh's Avatar
Yea mine does. My car has an A4 to M6 swap. I often wonder if I got the MC rod out of alignment.
But remembering back to the old days I used to take the clutch pedal out of the older 2nd gens and grease the plastic pivot bushings. That would solve the problem. Of course back then there was not as much wiring and stuff in the way, making the job much easier.
Old 10-26-2007, 10:40 AM
FNQUIKWS6's Avatar
Damn thats weird, my car also has an A4 to M6 swap. Could this cause problems if the MC rod was out of alignment?
Old 10-26-2007, 10:48 AM
redrider28287's Avatar
My clutch pedal will squeak on occasion. It comes and goes. No conversion here though.
Old 10-26-2007, 10:56 AM
Kleeborp the Moderator™
MeentSS02's Avatar
I've had it from time to time as well...seems to do it less just after I flush out the fluid, but also seems to be somewhat related to the ambient weather at the time.
Old 10-26-2007, 11:28 AM
FNQUIKWS6's Avatar
Maybe it is the weather, Its just now starting to get a little colder so that could be it.
Old 10-26-2007, 11:56 AM
Internet Mechanic
BlackScreaminMachine's Avatar
Its the spring that returns the pedal back to resting position, it needs to be lubricated.
Old 10-26-2007, 12:06 PM
Schitzo's Avatar
try spraying some lithium grease on the moving parts.
Old 10-26-2007, 12:20 PM
SS101's Avatar
i was just going to suggest that...99.9999999999999999999999999999999999999999 99999999999999999999999999999999999999999999999999 99999999999999999999999999999999999999999999999999 99999% of the time, if it's squeaky, it needs lube
Old 10-26-2007, 01:20 PM
wrd1972's Avatar
Normal, just lube the shaft.
Old 10-26-2007, 02:23 PM
Datzneat's Avatar
Mine just started doing that also. Is the spring easy to access?
Old 10-26-2007, 02:30 PM
Canada's Avatar
Mine is an a4 and my gas pedal squeaks. Defiantly annoying.
Old 10-26-2007, 08:29 PM
2000WhiteTA's Avatar
When my clutch pedal started squeeking I had to replace my master cylinder. Look at your master cylinder under the dash and see if there is fluid leaking out of it. If your master has fluid leaking out of it you will need to replace the master and the squeek will go away.
Old 10-26-2007, 09:50 PM
MrEddie's Avatar
Mine squeaked quite a bit right before the clutch return spring broke - didn't replace it. I have a fairly new master and it will make a slight squeak, but not bad. My Mazda 3 daily driver also squeaks a little as well, but no problems on either.
Old 10-27-2007, 08:19 AM
LS1W66's Avatar
I agree
Old 10-27-2007, 11:01 AM
Camaro01SS4life's Avatar
I think there is a service bulletin for this exact probem...Its the clutch return spring...Just through some grease on there to shut that thing up...I had one break...Its a PITA to install too...Not to mention the price for the spring
Kev
Old 10-27-2007, 04:28 PM
ae13291's Avatar
omg i have the same problem tooo!! it annoys the **** otta me, i jus went under there and sprayed it with silycon lube and that did not solve anything but i cant find where that return spring is anyways, i wish i could find it! but a quick fix 4 the problem is jus dump the clutch really fast with the car off and it would be fine but the noise would come back soon
Old 10-27-2007, 04:30 PM
NHRAMAN's Avatar
Location: Vancouver,[KITSILANO].B.C. Canada *WestCoast*
I use spray silicone on alot of parts...belt tensioner also...pulleys...just use a little.
Old 10-27-2007, 04:36 PM
00T\A's Avatar
Kev
Man speeks the truth about replacing one real PITA.
And the dealer wanted 39.00 for it
Old 10-28-2007, 11:30 AM
nighthawk355x's Avatar
That's the answer to ALL problems, not just this one in particular......back to kindergarden for me!
Ya know, I always wondered wtf that was. My girlfriend's old Firehawk did the same damn thing after we had a new clutch installed, only it was ALWAYS! Talk about f*in annoying!
Quick Reply: Do any one else's pedal squeak??
