Installing throw out bearing question
Pretty straight forward question here, when i'm putting the new throwout bearing back onto the slave do you just basically kindof twist and push it on till it snaps in place in a position where the front stops right before the splines on the input shaft?
I can phyiscally push the T/O bearing backwards toward the slave, and have it pop back foward again. I'm used to having a cluch fork, so this is a little bit different for me.
thanks.
thanks.
