Clutch pedal goes limp under hard acceleration
Old 10-27-2007, 07:51 PM
I Go To Costco's Avatar
Default Clutch pedal goes limp under hard acceleration
When I floor it in 1st or 2nd gear, from a stop or while rolling, the car will pull hard but when I clutch in to shift, it feels really soft until the catch point where it firms up. Then the clutch pedal stays soft like that for a while then after I shift to 3rd or 4th its good again. Anyone have any idea whats wrong? I'm pretty sure this isn't normal.
Old 10-28-2007, 01:52 AM
00T\A's Avatar
Not normal but common.
https://ls1tech.com/forums/manual-transmission/742741-sticking-clutch-pedal-write-up.html
Old 10-28-2007, 02:17 AM
gametech's Avatar
Let me guess. Headers? Use a higher temp rated fluid or wrap your lines.
Old 10-28-2007, 12:56 PM
JonB's Avatar
Originally Posted by 00T\A
You beat me to it.
Since you did't mention it has stuck to the floor yet I would recomend a good flush of the hydrolic fluid and also wrap the line from the master to the slave as already mentioned.
Quick Reply: Clutch pedal goes limp under hard acceleration
