alarm problem
Old 10-27-2007, 11:51 PM
JOEFASTZ28's Avatar
Default alarm problem
my alarm goes off when i press the lock botton on my keyless remote it just started today please help i dont want nobody jacking my ****
Old 10-28-2007, 01:27 PM
2001NBMZ28's Avatar
Does it do the same thing when arming it using the door lock button? Alarm going off for no reason just after arming usually means the shock sensor is bad - try unplugging it temporarily and see if it stops.
Old 10-28-2007, 05:31 PM
Copy & Paste Moderator
VIP1's Avatar
If the alarm was already set when you hit the lock button, its normal for the alarm to sound. I get it too. Sometimes when I'm approaching my car I accidentally hit the lock button instead of the unlock button and the alarm sounds. If this is the situation you are experiencing, it is normal.
