tuning for more cubes
If MAF sensor is not changed and the fuel injectors are the same, what do you edit (VE?) to get the proper AFR? You shouldn't change the MAF or IFR tables unless you have altered either one, right?
I am running an LS1 off a 2000 5.3 PCM after swapping in my truck. Changing only displacement, it's running way lean.
