Drag Racing Tech
competition engineering shock settings?
Old 10-28-2007, 06:14 PM
IrocZ's Avatar
Default competition engineering shock settings?
they have 30/70 40/60 and 50/50 written on the box, and XF, X, R on the box. Does 30/70 = XF..... 40/60 = X..... and 50/50 = R??????
Just put them on and I want to make sure I got them on 50/50. I have them set with the notch right above the R. Is that where it needs to be for the 50/50 setting?
Thanks
Old 10-28-2007, 07:33 PM
chrismorales75's Avatar
Competition engineering 3 way shocks use the following settings:
FRONT SHOCKS
R 60/40
F 80/20
XF 90/10
REAR SHOCKS
R 50/50
F 40/60
XF 30/70
I had best results with 50/50
You push the shock all the way down and turn it around a few times pressed all the way down, then stop it on "R" and without turning it pull it straight up, that will be 50/50
Old 10-28-2007, 09:44 PM
1CAMWNDR's Avatar
Agreed. R is what you want. Here's a question for you: Since all you do to adjust these is compress them, turn them a few times and stop on the mark you want and extend----could you adjust them while they are still mounted to the car?? Just unbolt them from the rearend, move the body up untill they stop, and turn. When you get to your new setting; pull it back down.
Seems like it would be the same to me. That would be a hell of a lot easier at the track.
Old 10-28-2007, 10:08 PM
You have to unbolt them from the top and compress the shock. Not sure you could see what setting they were on if you just unbolt the bottom.
If you could see the mark and read the setting on the shock, then yes you could unbolt them from the bottom and adjust them.
Old 10-29-2007, 01:34 PM
1CAMWNDR's Avatar
A red paint line on the top notch, and 3 red lines on the shock body marks and you'd have it.
Old 10-29-2007, 08:52 PM
IrocZ's Avatar
Thanks guys. I guess my stock rears were WAY past done.
Old 10-29-2007, 10:27 PM
Photochop's Avatar
I tried adjusting mine and just messed them up. Had to pull them off the car and tinker with them and I still don't think they're right. They're good shocks but adjustability is horrible.
Old 10-29-2007, 10:33 PM
they are pretty simple to adjust i think.
Old 10-30-2007, 02:50 PM
Retired Street Racer
Matt D's Avatar
50/50 is what I have mine set on.
Quick Reply: competition engineering shock settings?
