Coolant Leak
Coolant Leak
Ive got a coolant leak somewhere...
You can smell something real sweet coming from the engine bay, like pancake syrup... is there a flourescent dye that you can add to the coolant in order to find out where the leak is coming from?
Re: Coolant Leak
I found a pinched overflow tube...
Other than that... the water pump LOOKS like it leaked some fluid out that way. I'll go grab some pics of it.
Bottom of the motor is a orange mess.
Re: Coolant Leak
Re: Coolant Leak
Will do. Gonna get under tomorrow and clean the bottom of the engine up. You can still smell coolant from the engine bay after driving around for a while when the engine gets hot.
Re: Coolant Leak
Just change the water pump now. A while back I kept smelling coolant, broke out the dye and the pressurizer and nothing, not even a pinhole leak. A week later, my water pump got pretty ugly. The water pumps are known to go on these cars, so might as well just get it over with.
Re: Coolant Leak
20 bucks says its just a gasket. The pumps on our cars are actually pretty good. This same thing happened to me about a year and a half ago. I was told (by a gm tech ) it was the pump going bad, and was leaking from the weap hole. I went and ordered a new pump and when I was replacing it I found out it was just a torn gasket. I went ahead and installed the new pump anyway though, since I already had it. Your pictures look just like mine did. It looks like its leaking on the driverside. Change the gaskets brfore you go and spend $150 on a new pump.
p/n: 12559271 (you need 2)
