c230 plug????
c230 plug????
i know this plug has the serial data for the gauges, but what does it plug into? i was thinking of trying to use stock gauges (or at least use them to get it running and i realized i have no idea what this plug hooks up too!!!
is it just an extension to plug into the gauges? or does it plug into somthing else then from there to the gauges?
same question for the c230 plug (although from searching i know i just cut it up and use a aldl port of any 96 and up gm).
and does anyone know if there is a diff between a 98 cluster and a 99+ up cluster? if i get gauges off ebay, sometimes i noticed the listings say 98 and up etc. but i have a harness from a 01?
C220 and C230 talk to all of the rest of the car that is not in the engine compartment. There is a pin-out with circuit numbers and description in the Fbody manual. We're doing a swap with '99 Camaro motor & harness & PCM. Pm me - I'll take pics of the pages in my manual for you
