Nitrous Oxide - Dual Stage dry kit
View Full Version : Dual Stage dry kit
chrismorales75
10-29-2007, 11:29 PM
What jetting/ shot would you recommend for a 1998 ls1, stock motor with a 255lph fuel pump on pump gas.
I would like to run two stages.
Chris@NitroDaves
10-30-2007, 09:01 AM
Wiht you havinng the stock motor i wouldn't suggest you go over a 150hp shot. There are people that are spraying more than that on the stock motors but keep in mind that at any time it could go BOOM!! 2 stage dry jetting would be
.031 + .031 = 70hp
.035 + .035 = 100hp
.041 + .041 = 150hp
-Chris
chrismorales75
10-30-2007, 11:22 AM
[QUOTE=Chris@NitroDaves;8034925]Wiht you havinng the stock motor i wouldn't suggest you go over a 150hp shot. There are people that are spraying more than that on the stock motors but keep in mind that at any time it could go BOOM!! 2 stage dry jetting would be
.031 + .031 = 70hp
.035 + .035 = 100hp
.041 + .041 = 150hp
Is the .041 jet a 75 hp single jet power rating? I will be using a single nozzle and will just use the fuel side for n20. So I think I will go with 125.
Would that be a single .041 and .035 jet to = 125?
Would just like to double check it.
