I Need Gears ($$$$$)
well i pulled the diff. cover off today and what did i see ...only about half of the pinion gear teeth were on the pinion..and the rest were in the bottom of the carrier...soo my ? is ..do any of u guys have a good set of 3:73s/4:11s that i can get off u for pretty cheap (not tryin to low ball..)....its a 95 Ta ...stock 10 bolt.. and if remember there 7.5 carrier..but plz help..im driving my diesel that gets about 5 miles a gallan and haing every min of it...
please pm me with what ya got
Justin Reynolds
Justin Reynolds
have a brand new set of AAM 3.73's for 3 series carrier in the 7.5 10 bolt. I bolted them in but realized I had a 2 series carrier so I pulled them out again before I even closed up the pumpkin.
LS1TECH Sponsor
We carry a few sets in stock
3 series carrier
http://motivegear.carshopinc.com/pro.../78847/G875373
http://powertransferparts.carshopinc.../43440/GM75373
2 series carrier
http://powertransferparts.carshopinc...43441/GM75373T
3 series carrier
2 series carrier
why does it seem like you are the same person?? other person has been banned for using a bunch of screen names.
Hey,
Where are the 3.73 gears that I paid for over 1 month ago?
You said that they were sent out 1 week ago Friday? Where is the tracking information?
Am I going to have to come down there and pick them up?
Why don't you just send me a refund, cause I'm sick of having my car on jack stands waiting for these gears you promised to ship out asap.
I wanted to send a private message but server said you are not accepting messages at this time.
hmmmm
i want to buy all parts need for a m6 conversion i also am selling my a4 parts also looking two trade some parts
PARTS NEEDED
shifter perfer: after market depending on price
shifter ****: want black ball shifter with ether t/a bird on it or white 1-6/r
transmission: t56 low miles from a gt0 perferd
bellhousing: t56 not cracked or damaged
transmount: pollyurthane
pilot bearing: new
tranny crossmember: t56 for 2000 t/a
clutch: ls7 or after market
flywheel: ls7 or after market
hydraulics: prefer after market adjustable parts
pedal assembly: for 2000 f body with t56
shift plate:
pcm: 2000 t/a t56
and any other parts i may have missed
PARTS SELLING / TRADEING
shifter: 2000 t/a 4l60e shifter
shifter ****: 2000 t/a black a4 shifter
shifter cables: f body 98-02 shifter cables
transmission: 98 - 00 4l60e trans
bellhouseing: 98 - 00 4l60e trans
trans mount: 98 - 00 4l60e trans
trans crossmember: 98 - 00 4l60e trans
flex plate: 98 - 00 4l60e trans
pcm: 2000 t/a 4l60e computer
torque converter: 98 - 00 4l60e trans
DEPENDING ON COST I MIGHT BUY A GOOD USED/NEW/BUILT/LOW MILES 4L60E/4L65E
PARTS NEEDED
pilot bearing: new
shift plate:
pcm: 2000 t/a t56
IN THE WORKS:
ls1 / t56 build
yeah your the same person. i should say persons
