Where can I find a intercooler like this?
Old 10-31-2007, 01:29 PM
1INSANEGTO's Avatar
Default Where can I find a intercooler like this?
Old 10-31-2007, 01:39 PM
Fireball's Avatar
probably have one custom made
Old 10-31-2007, 01:40 PM
ddnspider's Avatar
Received 1,736 Likes on 1,297 Posts
ebay had some like that at some point might want to look there
Old 10-31-2007, 01:47 PM
stevieturbo's Avatar
I think the APS twin turbo IC is a bit like that on some cars.
Old 10-31-2007, 06:46 PM
Ironmancan's Avatar
APS
Attached Thumbnails Where can I find a intercooler like this?-gto_front_500.jpg
Old 10-31-2007, 07:41 PM
618HAWK's Avatar
This place can make any thing you can dream of. Ask for Marty great guy to deal with.
nonsponserurls are not allowed!!
Old 10-31-2007, 09:19 PM
squealingtires's Avatar
This is the APS intercooler for the twin turbo f-body cars. It looks like this is what you are looking for. Not sure if they will sell it by itself either. Good Luck!
Old 10-31-2007, 10:01 PM
01bad ss's Avatar
[url]blahblah
Marty makes some great products at an even better price.Got an air to air custom made from him at a great price and got it in less than a week.All you need to do is send him a drawing with measurement specs and he can do it up for you. He can also make custom radiators,fuel cells,water to air intercooler systems and much more. I think that Marty also had the intercooler that is in the first post laying around the shop when I stopped over there earlier this year to get my intercooler built. He said it was for a corvette I think.....
Old 10-31-2007, 11:54 PM
BigJls1's Avatar
flea-bay has them, type " 2 in 1 out intercooler" or type "camaro intercooler".
Old 11-02-2007, 07:56 AM
1INSANEGTO's Avatar
I will call Marty as I need a radiator also. I have a quote on a custom radiator but I am sure he can beat that if I am getting a intercooler and radiator.
Also the flea-bay intercoolers will not support 1000hp most of the time. I know a guy who had one and did the cfm math or what ever it the thing stated 1493cfm and once he ran the numbers it came out to 1000cfm.
Old 11-02-2007, 08:54 AM
smokinHawk's Avatar
KP and pure evl are closose to 100orwhp on them
KP is knocking on 8's doors with one, so its good enough for me
I also modded my flea-bay IC a little bit by flipping the end cap and putting a 4" outlet on it so that should help some more.
Old 11-02-2007, 09:32 AM
1INSANEGTO's Avatar
Cool I guess you can't listen to everyone else I guess
Old 11-02-2007, 09:36 AM
1INSANEGTO's Avatar
Here is the ebay I found
Core Size, 25" X 6" X 3.5"
1-3" outlet and 2-2.5" inlets
Outlet is angled 15 degrees
1453 CFM flow rate
968 HP efficient
1.5psi pressure drop at 1453cfm
Old 11-02-2007, 09:57 AM
FWIW, this is my crappy DIY IC core. Ive been logging boost before, and after this IC, and I was shocked at the results. At virtually all times, there is less that 2psi difference across the core.
Its usually around 1psi when on boost though. Given how crappy it is, with 2 cores welded together etc, I was amazed. I expected there to be a huge loss. I have improved the airflow exit slightly compared to those pics.
I was seeing around a max of 20psi manifold pressure when logging.
Each core has about 11" long tubes, and is 13" tall/deep, and around 3" thick.
it would be interesting to see the restriction of other cores in real life.
Old 11-02-2007, 01:12 PM
BLNLS1/RX7's Avatar
You need to talk to Bob at Exotic Performance Plus.com.
Quick Reply: Where can I find a intercooler like this?
