Anybody done this mod to TB bypass? (pics)
Old 06-13-2003, 02:39 PM
Larry's Avatar
Default Anybody done this mod to TB bypass? (pics)
I have not just bypassed my throttle body but also blocked off the radiator and tubing ports. Has anybody done this? Any ill effects?
http://www.mustangmods.com/data/440/MVC-006S.JPG
http://www.mustangmods.com/data/440/MVC-007S.JPG
Old 06-16-2003, 11:13 AM
Mustang Hat'r 2's Avatar
Default Re: Anybody done this mod to TB bypass? (pics)
I wouldnt do that, those are the coolent return lines for the heads they help remove air pockets.
Old 06-16-2003, 11:17 AM
LS1TECH Sponsor
Magnus's Avatar
I wouldn't do that either unless you install a manual bleeder on that coolant line. It's very important to the coolant system bleeding setup.
Old 06-16-2003, 11:29 AM
nc z28's Avatar
i used the bmr kit. but it looks as if you blocked off the tubes and you havent run the lines together. your setup looks totaly different than mine
Old 06-16-2003, 01:29 PM
Chris99WS6PWTMET's Avatar
Probably not a good idea.
Old 06-16-2003, 02:19 PM
Ferocity02's Avatar
Don't do that, just connect the two ends together.
Old 06-16-2003, 06:03 PM
DALLAS's Avatar
Yeah, if anybody could find out more info about this mod that would be great, 'cause i pretty much did the same thing larry did. i read it in an ls1/ls6 performance book, and that was one of the mods they said was worth doing. i didn't read anything about connecting any lines together, nor did it say anything about the heads.
Old 06-16-2003, 06:12 PM
LS1TECH Sponsor
Magnus's Avatar
you need to connect them together or install a manual bleeder valve..
the air will go to the top of those tubes, but has no way to escape now.
Old 06-16-2003, 10:19 PM
FrankSS's Avatar
what everyone else said. just run a line between the 2 and you will be good to go
Old 06-17-2003, 01:27 AM
Judd's Avatar
Yea, run it back to the radiator like everyone else said.
I tried a "New and Improved" TB bypass mod.. I got a windshield washer tank and motor, hooked it up to the throttle body and battery, then to a switch. I put coolant and ice in the tank. I figured it would cool the air better at the strip kinda like a "cool can" cools gas.
Didn't see any gains with it and took it off. Looked like a rig {which it was}. Worth a try though. Didn't lose anything but my time.
