Nitrous Oxide - Launching on n2o w/ a M6
View Full Version : Launching on n2o w/ a M6
Sluggish
10-31-2007, 08:17 PM
What are you guy using to launch on nitrous with a 6 speed. I have a MS4 cam only car on 17" ET streets. Im going to convert my dry to a nitrous outlet 90mm plate. I have a TPS/window switch now. I was thinking I could bring the rpms up then when I got WOT it would spray. But the hold up is I also want a 2 step. Is anyone doing this same thing. n20 off the line + 2 step?
1nastyss
10-31-2007, 08:44 PM
awesome question, i would also like to know
TTT
m_williams
10-31-2007, 08:58 PM
TTT
:metoo:
black01_WS6
11-01-2007, 05:51 AM
A guy around here is going to be doign that with his SS. I know he was having a little difficulty doing it.
Jditlfm
11-01-2007, 08:48 AM
I deactivate the spray hold the two step button down launch and then as fast as i can i flip the activation switch. I think thats the safest way to do it. If you run a WOT switch and a window switch like i do you could have the activation switch on and just not press the throttle all the way down when your on the two step then after you launch press it down that last bit. Its kinda unsafe tho because if you forget and push the pedal all the way down or push it down before you let go of the two step button your spraying on your two step. That = bad news.
Joey@Tick
11-01-2007, 09:02 AM
I follow this routine after the burnout:
Activate the nitrous
Purge
Stage
Put the car on the 6800RPM two step (at WOT)
Dump the clutch on the last yellow
Since I'm already at WOT as soon as the clutch is dumped, the nitrous is automatically activated. Since we launch the car so high in the RPM range, it stays above the 3500RPM activation window.
Spraying out of the hole fuels my 3700LB pig to 1.40 60' times. :devil:
DuronClocker
11-01-2007, 09:28 AM
Purge
Stage
Except for the 2-step, this is my plan of attack for Saturday. I'll be dumping from around 6k and see what RPMs that nets me off the line, and then I'll adjust the window accordingly. Was hoping to be able to set it at 3500 as well and have it hit off the line. I doubt I'll have the traction your car will, so I might not drop RPM quite as much.
Sluggish
11-01-2007, 10:18 AM
so the 2 step and the nitrous are both trigger at the same time by the clutch being released? Your using a wot switch mounted under the dash for this?
TINKRD
11-01-2007, 11:07 AM
i was spraying 300 straight out of the hole. no two step, just a WOT switch.
burnout
activate nitrous
purge
hold RPM's at 5500
dump clutch
netted me 1.40 60 ft's w/ bilstein shocks!
nevermind the crappy burn out or rev limiter....
http://www.youtube.com/watch?v=0724awWcAHw
02NBMWS6
11-01-2007, 11:24 AM
burnout
activate nitrous
purge
hold RPM's at 5500
dump clutch
:werd:
I just dump the clutch with the rpms higher then where the window switch is set to come on at and hold on for 1.4 60's :D No two step necessary
venom ws7
11-01-2007, 11:46 AM
burnout
activate nitrous
purge
hold RPM's at 5500
dump clutch
Great time man what is the engine setup??? any 1/4 times????
02NBMWS6
11-01-2007, 11:50 AM
burnout
activate nitrous
purge
hold RPM's at 5500
dump clutch
what did you run? that was some damn nice sounding gear tagging man!
Sluggish
11-01-2007, 12:00 PM
That's what I may do. Just use the 2 step for N/A runs. I hope my suspension tires can hold up to it. I will be happy with a 1.5x on a 150 shot
venom ws7
11-01-2007, 12:01 PM
It ran 6.3 and hitting the rev limiter 7 times.
This was quote from youtube Comments.
NBMWS6 Your car is very sick too those are great times with full weight car.
02NBMWS6
11-01-2007, 12:10 PM
sweet! Thanks man, it'll be a whole lot sicker this time around :D
Joey@Tick
11-01-2007, 12:59 PM
Except for the 2-step, this is my plan of attack for Saturday. I'll be dumping from around 6k and see what RPMs that nets me off the line, and then I'll adjust the window accordingly. Was hoping to be able to set it at 3500 as well and have it hit off the line. I doubt I'll have the traction your car will, so I might not drop RPM quite as much.Good luck! I hope everything goes well for you. My car dead hooked from 6800 and bogged to ~3700. If your car spins, it won't drop as much - but the nitrous is going to make it spin more!so the 2 step and the nitrous are both trigger at the same time by the clutch being released? Your using a wot switch mounted under the dash for this?The nitrous is activated when the two-step is deactivated. My WOT switch is under the throttle arm on the TB.
For a video of my car leaving on spray off the two step, check the link in my signature.
TINKRD
11-01-2007, 01:27 PM
6.38 at 97mph.
previous before that was a 6.48 at 106
i guesstimate it would have been a .32ish if i had shifted to 4th gear.
forged 346 w/ lots of sauce.
motor has been out of that car for a year now and have been building a new setup. :)
JDP
11-01-2007, 04:23 PM
to bad we can hardly hear your car over the beast next to you
venom ws7
11-01-2007, 09:38 PM
Very true.
Thats RPM Black camaro right?????
Do Work Son!
11-02-2007, 01:01 AM
That was a nasty pass!!! what bottom end was in that thing thehn? head cam setup?
greyghost4x4
11-02-2007, 08:23 AM
i follow this routine....
1. Burnout
2.Activate kit, purge kit through motor during burnout
3.5 grand clutch drop
no window switch just a WOT switch prayin i dont miss a gear! KNOCK on wood i havent yet!
slowprocess
11-02-2007, 08:26 AM
1. Burnout
When did you get nitrous? :D
greyghost4x4
11-02-2007, 08:27 AM
ya know... when i raced beau's car.. we had a "kit" on it
slowprocess
11-02-2007, 08:33 AM
Is that what you call what we had on the car? :emb:
Joey@Tick
11-02-2007, 08:36 AM
Very true.
Thats RPM Black camaro right?????Yes, that is Brad Boone's RPM Shop Car. Very nasty!!to bad we can hardly hear your car over the beast next to youVery true.That was a nasty pass!!! what bottom end was in that thing thehn? head cam setup?It's a W2W 427 race motor. The second fastest nitroused LSx car in the nation right now.
greyghost4x4
11-02-2007, 08:38 AM
ok... so we had some lines, i little giggle gas(mostly sulfur), WOT switch, and about % gallons of 104(mostly lead)lol
so yea... a "kit"
ssfast99
11-02-2007, 03:47 PM
i dont know if this helps, but i am a t-rex 243 car with a m6 and i sprayed 100 shot out of the hole. i just heated my et streets and revved to about 5800 rpm turned the switch on and launched. stock rear held together for awhile.
pddye
11-02-2007, 04:31 PM
I have the cam in my sig with stock heads. I shoot 150 out of the hole with a msd window switch and wot switch on the throttle body. With only suspension mods being a umi torque arm and 1 year old comp engineering rear shocks with used m/t et street radials its running pretty decent.
ls2 bait
11-02-2007, 08:46 PM
im having a heck of a time figuring this out myself. i know its possible i just dont know how to get it to activate as soon as the 2 step deactivates.
Beaflag VonRathburg
11-02-2007, 10:13 PM
I have no idea about eletronics, but could you just use the same switch? As in wire the nitrous on activation to the same parameter that is the two step off.
ls2 bait
11-03-2007, 09:24 AM
i have no idea. the 2 step stays on during the run but deactivates once the clutch pedal is released. the only thing i can think of right now is some sort of micro switch on the clutch pedal.
WheelsUp84z
11-03-2007, 11:29 AM
check out the sweet wiring sticky....it will tell you how to run things
