Dynamometer Results & Comparisons - Comparison between my Cam only LS1 and my old Mustang 347
347fairless
11-01-2007, 12:48 PM
Just thought this might be interesting.
TA -
LS6 Intake stock
Cam only - Vindicator - .608/.598 240/244 110+4
1 3/4 LT headers
Ypipe Flowmaster merge
Flowmaster catback (bigger series mufflers)
Bo White TB
Gran MAS
42lb inj.
TR55 plugs
Chumma tune
Mustang - 347 - H/C/I
N-113 cam @.50 .576/.576 270/278 108
AFR 205 heads box stock 308/231 cfm at .600
Victor JR intak port matched
BG 750 carb
CHP 347 rotating assembly
Comp 1.6 rockers
MSD 6al and blaster coil
MAc 1 3/4 LT headers
3 inch powerchamber hpipe
3 inch Mac dumped exhaust
Both cars dynoed through manual trannies and 8.8's (the same 8.8 lol) and 410 gears.
TA in Blue, Mustang in Red
http://home.dejazzd.com/shotat1/webpics/mustang/347%20vs%20TA.JPG
quiet_storm98
11-01-2007, 08:11 PM
that is very interesting that with just a cam the ta is putting out almost the same that the fully built stang did.
venom ws7
11-01-2007, 09:23 PM
Great Comparison man thanks for sharing oh and great cam only numbers with T/A.
GM all the way.
lol.
COOKIE MONSTER
11-01-2007, 09:33 PM
Damn, you almost go tthe same numbers as I did with H/C/90/90/UDP/etc!
And I'm running the MS3...
347fairless
11-02-2007, 10:33 AM
Just thought it was a cool comparison, carb vs EFI, Ford vs GM. Compression on the 347 was 11:1. Wonder if it was the Ford cam or the carb on the Ford that cost all that torque. The Ford carb was never tuned.
bad6as
11-02-2007, 04:51 PM
did you need to flycut with the vindy?
BlackScreaminMachine
11-02-2007, 04:54 PM
Yea, the T/A would smash the Stang, even though it had a lil more peak, under the curve is where it mattered.
raymond mckinney
11-02-2007, 08:27 PM
That's great results for a 347 most around Tampa all motor are at about 340-360 wheel! And most cam only ls1's are around 400-420 wheel. Both good running cars u have for the mods.
NemeSS
11-02-2007, 09:00 PM
strong numbers for a 347 stroker windsor
informative info
ravensfan
11-03-2007, 02:33 PM
Exactly, this is a GREAT graph to show those people that care about peak power.
rel3rd
11-03-2007, 05:44 PM
Mike, are you coming to the SuperStallions race on November 17th?
347fairless
11-04-2007, 12:05 AM
Hey Bob. I am trying to track down another ticket. I waited too long...
As for the TA smashing the stang, the stang went 11.1 @ 122mph. with a C4 and a 2500 stall convertor on stock suspension. Pretty much a matter of weight and softer suspension.
nice comparison between the two.
rel3rd
11-04-2007, 09:40 AM
Check your PM's :secret2:
TurboLark
11-05-2007, 10:26 PM
That 5.0 cam is huge. Would have picked up bottom end with a cam sized like the LS cam, though not sure how much may be lost on the top end.
I had a cam that was 272 at .050 with .620 lift 104 LS and it didnt want to get out of its own way until 4500 in a 306 Ford. Had a 5K convertor and 5.14's. Shifted at 8700rpm. What a ride that was in the 2100lb 'stang it was in.:chug:
Oh, lack of carb tuning can hurt big time.
BADSZ28
11-06-2007, 09:30 AM
What intake are you running?
PewterScreaminMach
11-06-2007, 10:18 AM
That's a great comparison. I would imagine the Stang was much much lighter and would pull the TA, maybe not so much down below 4000-4500 or so where the TA's making all of that torque, but above that, that Stang must fly!
X2 on the flycutting question. I'll do a search as well because I think I remember you posting when you installed that cam.
slick1851
11-22-2007, 03:29 PM
I do not understand why people dont get there shit tuned
98camaroLS1M6
11-23-2007, 11:45 PM
nice comparison!!!
On the Stangs cam...is that 270/278 at .050 or advertised?? If thats at .050 thats a big sum bitch. I cant beleive it ran good with only a 2500 stall! Both sick fast cars.
347fairless
12-02-2007, 02:50 PM
Best 60 ft with the stang was only 1.67 lol. Bought the c4, stall, and shifter out of the back of a car at Atco for $300
TA had a stock LS6 intake.
Jasperstang308
04-24-2008, 12:18 PM
both very good numbers.
Jasperstang308
04-24-2008, 12:20 PM
you guys also gotta remember your stock heads flows a lot better then ours. Also i wonder if that stroker would have picked any more up with a pro systems carb.
very nice numbers again out of a stockish ls1
Stang's Bane
04-24-2008, 12:22 PM
The heads on the 347 here outflow a stock set of ls1 heads by a mile.
s346k
04-24-2008, 01:02 PM
i thought the vindicator was on a 112+4 lsa?
Jasperstang308
04-25-2008, 10:32 AM
i understand that. i was just referring to how well they flowed stock
CraZee ZO6
04-25-2008, 12:47 PM
is this with ls1 heads or ls6?
jbs02somws6
04-28-2008, 10:04 AM
Old thread guys, I thought for that Fairless347 had got his TA back for a minute when I saw this thread.
