Do you have a Z06 Intake Manifold?
Old 06-14-2003, 11:09 PM
CamaroSS's Avatar
Default Do you have a Z06 Intake Manifold?
Accordng to High Performance Pontiac Magazine, all 2001 and 2002 LS1 F-Bodies come stock with an LS6 Intake Manifold. Can anyone back this up?
Also, according to GM High Tech Performance Magazine, select few LS1 F-bodies have a LS6 blocks. According to the Block ID# they gave in the Magazine, I have an LS6 Block. Can anyone back this up?
Old 06-14-2003, 11:58 PM
mike c.'s Avatar
Default Re: Do you have a Z06 Intake Manifold?
the 01-02 f-bodies do have the ls6 intake. i don't know anything about the ls6 block being in some f-bodies. you have me wondering now.
Old 06-15-2003, 12:12 AM
1999_SS_M6's Avatar
All 01+ F-cars have the LS6 intake, some 01+ F-cars do have the LS6 block, some have the LS1. It had to do with supply shortages I believe. Do a search on here, or on LS1.com. There was a thread about this a couple months ago.
The only real difference between blocks, to my knowledge, is openings in the bulkheads between cylinders. It supposedly relieves crankcase pressure at high RPM.
Old 06-16-2003, 11:41 AM
Shane's Avatar
LS6 intake is on all 01+ as mentioned.
LS6 block is in a few (10%?) 01s and some (25%) 02s. The LS6 block has "improved bay-to-bay breathing", and has a different casting process & materials to make it stronger. Probably doesn't make a *huge* difference, but I'm sure it doesn't hurt.
I have the LS1 block... :/
good luck,
Shane
Old 06-16-2003, 02:43 PM
numbZ's Avatar
good luck,
Shane
Yeah.Exactly what he said.
Old 06-17-2003, 01:40 AM
BlackCamaroSS02's Avatar
LS6 Block here if you look under the car right beside the bar code sticker on the underside of the engine there should be a cast in block number the LS1 is 12561166 on a LS6 its 12561168
