Paint & Body Work - WS6 driver side fender alignment
Malicious
11-02-2007, 03:16 PM
Car had the 98+ WS6 front end conversion done on it, and whoever did it didn't do something right, because if the fender gets hot it shifts and the door hangs on it. Previous owner bought the car like that and it did it to him once or twice and did it to my wife today. Anyone got any info on how to get the fender off(never done it, probably just stumble through it), and a good way to be sure its aligned?
Malicious
11-02-2007, 03:20 PM
Forgot to mention the fender is already bent where the former owner opened the door with it hung up, so if anyone might know where to get a replacement black fender that'd be awesome. Got a feeling there might be more wrong on this than just a bad fender install :(
phantomzer0
11-02-2007, 03:37 PM
There is a tab that is under the fender. This problem is caused by that tab getting bent. It has two screws on it. Most likely got bent from improperly jacking up the car.
Malicious
11-02-2007, 04:57 PM
I'll take a look. Is it possible to just straighten that and go on my way or would it be better to try to find a replacement fender? :bang:
transambandit
11-02-2007, 05:01 PM
it is either the tab, it says do not jack right on it, but if it is bent just take a block of wood and hammer it straight. If its not that then chances are you have to adjust it from inside the fender. If you look in your door jam you will see where the fender bolts to the car, where the bolt goes is oval and it can be adjusted in and out. Reach in there if you can and loosen the bolt then adjust the fender slightly, tighten it back up.
Malicious
11-02-2007, 05:02 PM
Awesome thanks for the tips guys! I'll check that out tomorrow, stuck at work tonight :(
Malicious
11-02-2007, 08:35 PM
I didn't see any of the oval bolt holes inside by where the door swings open, but plenty in the engine bay. They look like they're adjusted all the way away from the door, which leads me to think the fenders sitting either too high or too low by the door. Any other ideas before I try to figure this out tomorrow? :P
phantomzer0
11-02-2007, 08:48 PM
Hmm, I had this problem on my Camaro for the longest time and all I did was adjust the bolts in the fender and re-bend that tab at the bottom. Fixed me right up. Maybe your door is sagging and that's what needs to be adjusted.
Malicious
11-02-2007, 09:03 PM
Yeah it is sagging some, whats the way to fix that? I helped my pops many years ago do that to his 77 big block TA he had and I don't for the life of me remember how... I'll check the fender tab and the bolt position, but if someones got tips on the door thing that'd be awesome too..
phantomzer0
11-03-2007, 10:58 AM
There are 2 hinges with 2 screws on the inside of the door. What you need to do, and it's a real bitch, is loosen the screws and with the help of a partner lift the door to the idle height, then tighten the screws. It takes some patience and a bit of time, but it can be done. Just keep loosening the screws and tightening them.
Malicious
11-03-2007, 01:14 PM
Cool, buddy of mine and I had the same idea, but I'm going to be doing it alone, so I'm borrowing a jack and just going to go with it slow. Thanks for the advice :D
Malicious
11-03-2007, 06:46 PM
No real luck on the fender or the door today... no luck on the wiper motor either lol... couldn't get the wiper arm off to try to get the old motor out, need some WD40 or something. Too many little damn things..... =(
