Sponsored by: DashLynx
Another piece wrapped
Old 11-03-2007, 06:02 PM
2K2WS6TA's Avatar
Default Another piece wrapped
As promised I wrapped another piece of the interior in "pleather"
and put together a quick guide to how to do it, so without further BS here goes
First off pic the piece you want to wrap (I chose the kick panel for today)
Secondly cut out your material in the rough shape of the piece to be wrapped, allow [plenty of excess so you can wrap it around the back
Third apply the contact cement to both the piece to be wrapped ant the back side of the material (follow the instructions on the adhesive you use, some say wait for x mins till it gets tacky, others don't, and some say use on one piece, and others say coat both pieces)make sure you get even coverage, or you'll have spaces that don't stick and that results in wrinkles or bubbles
Forth, this is the most time consuming step, now you have to work the material to fit the contours of the part, use a hair dryer to stretch the pleather, you'll have to make relief cuts in the corners too, and even add some glue, that's why I use the brush, so I can add more glue if I need to
Patience is the key here, take your time and get the material stretched cut and glued so you dont have wrinkles or air bubbles
once you get it looking like you want it, trim the back, (add some bling if you want) stand back pop the top on a cold beverage, and admire your work
I usually wait about 24 hrs before re installing it in the car, gives the glue a chance to set up
Although I did the kick panel the process is the same no matter what piece you choose to do, take your time, do it right and it'll look great
So there you go the quick guide to wrapping your interior, any questions you can either post em here or PM me
Good luck on your project
Old 11-03-2007, 08:53 PM
Big Z's Avatar
hmm i wonder if i could change my interior color to black by doing this.... knowing me it would never be done
Old 11-03-2007, 09:26 PM
3800RS's Avatar
cool, nice little writeup also
Old 11-03-2007, 10:15 PM
Reject's Avatar
super badass, where did you get the pleather at?
Old 11-03-2007, 10:17 PM
ApexVIII's Avatar
looks good! im doing my interior also!
Old 11-04-2007, 11:19 AM
2K2WS6TA's Avatar
Hobby Lobby
Old 11-04-2007, 12:23 PM
goldnz's Avatar
how much did u pay for the pleather
Old 11-04-2007, 01:34 PM
Reject's Avatar
really?! wow that's awsome. got a p/n or name or anything like that to loook it up over here?
Old 11-04-2007, 02:05 PM
2K2WS6TA's Avatar
Sorry no p/n, but go back in the fabric section, and you should be able to find it, I chose it because it has a similar grain pattern, and color to the "leather" on the dash, and fits in quite well
The cost was ~ $7 per yard, and I got 5 yards, but go to hobby lobbys web site and print the 40% off coupon, and get it for ~ $4
FWIW I'll probably need more than the 5 yds, probbably end up around 10 to do all the plastic in the interior (sail panels, door panels, kick panels, back hatch panels, etc etc)
Old 11-04-2007, 04:22 PM
dmoss69's Avatar
Default Nice CAR!!!
APEX III, I like that car you have in your sig!!!!
Check mine out!!!
D Moss
Old 11-05-2007, 10:29 AM
TORK?'s Avatar
So if we do this then decide it looks like crap and try to take off the pleather is the panel going to be all f'd up with the glue all over everything?
Old 11-05-2007, 12:42 PM
RickyMartinZ28's Avatar
Yes...
Old 11-05-2007, 12:52 PM
vikingramair's Avatar
Nice!!
Old 11-05-2007, 04:11 PM
2K2WS6TA's Avatar
Pretty much, so don't mess it up
Old 11-05-2007, 04:22 PM
noxiouSS's Avatar
what glue did you use? 3m?
Old 11-05-2007, 06:46 PM
2K2WS6TA's Avatar
Weldwood contact cement, made by Dap, also used the 3M Super Trim Adhesive (spray can)
Old 11-06-2007, 05:40 PM
noxiouSS's Avatar
thanks for the info. I'll be posting my progress as soon as i get around to it.
Old 11-06-2007, 05:55 PM
dmoss69's Avatar
Default Glue
I'm sure there is some kind of adheasive removable stuff you could take this stuff off if you didn't like the pleather.
D Moss
Quick Reply: Another piece wrapped
