slave cylinder keeps breaking!!!!!!
Old 11-04-2007, 09:54 AM
hnaskoct's Avatar
Default slave cylinder keeps breaking!!!!!!
i have broken a slave cylinder for the 6th time in 2 or 3 months what can keep causing this problem???? when i jam on it to go 2 a gear that when it breaks and all my fluid leaks out could it be a bad master????i really need some help on this...
Attached Thumbnails slave cylinder keeps breaking!!!!!!-slave2.jpg   slave cylinder keeps breaking!!!!!!-slave1.jpg
Old 11-04-2007, 07:40 PM
wrencher
wrencher's Avatar
Well did this start after you changed something?
Did the problem start after a clutch install?
Would have to say that the problem is either the trans/bell alignment, or the pressure plate's installed height.
Old 11-04-2007, 09:21 PM
hnaskoct's Avatar
up to top
Old 11-05-2007, 11:16 AM
hnaskoct's Avatar
to the top
Old 11-05-2007, 12:04 PM
98TADRIVER's Avatar
do you use a spacer shim behind the slave cyl?
Old 11-05-2007, 02:33 PM
hnaskoct's Avatar
no...
Old 11-06-2007, 11:56 PM
hnaskoct's Avatar
to the top
Old 11-07-2007, 11:30 AM
blk00ss's Avatar
What kind of slave are you buying? GM? What model number? There are a couple of different models.
Old 11-07-2007, 01:23 PM
Sharpe's Avatar
Did you miss this post, or...?
Old 06-25-2017, 11:52 PM
UsmcAlston's Avatar
having the the same issue any ideas?
Old 07-04-2017, 01:01 AM
01cam's Avatar
I have this same problem. Its the 3rd slave cylinder in 2 years ive had to replace.
Old 07-04-2017, 09:26 PM
S10xGN's Avatar
Just a guess, could an over-travel situation. Try gently pressing the pedal, if it gets hard before it hits the floor, you're over-pressuring the slave. Try pedal stop...
Old 07-06-2017, 12:09 PM
calhoon's Avatar
this is an alignment issue. the bell is not centering the trans
Quick Reply: slave cylinder keeps breaking!!!!!!
