harlan 2step
assuming you have the brake activated by a switch that supplies 12 volts......
Ground the gray wire from the 2 step.
Get a standard 12V relay.
85 on the relay to ground
86 on the relay to the connection between your T-brake switch and the brake solenoid
87 on the relay to the white wire on the 2 step
30 on the relay to ground.
relay should click when you hit the T-brake.
