Has anyone run LS6 heads milled to 62cc and ran up to 15 lbs of boost?
Old 11-05-2007, 06:34 PM
Chicago Crew UnderBoss's Avatar
Default Has anyone run LS6 heads milled to 62cc and ran up to 15 lbs of boost?
On a stock displacement 346/7 forged motor? Thinking of milling my ported TEA LS6 heads slightly down to 62cc so i can reach my desired compression; and has anyone done this successfuly for a sig. period of time (without having issues with the heads blowing head gaskets, etc., etc.).
Old 11-05-2007, 06:47 PM
LS1Tech Co-Founder
Pro Stock John's Avatar
Received 1,099 Likes on 721 Posts
2cc's cut on the heads shouldn't be too bad, maybe call Bill @ Opel Engineering in Streamwood and see what he says.
Old 11-05-2007, 06:54 PM
Yeah JOHN I am thinking this is very doable but need to make up my final decison tommorrow and leaning towards the 62cc milling as its really a small amount of material and I won't see more than 14 to 15 lbs of boost MAX when I am driving her ***** to the wall.
Old 11-05-2007, 07:16 PM
6 Second Club Moderator
LASTLS1's Avatar
I wouldn't cut them. It's not worth what you have to gain IMO.
Old 11-05-2007, 07:17 PM
HUNTER02SS's Avatar
My Dart's were 62cc's and I was running 18lbs. with them.Seem to work good.
Old 11-05-2007, 08:43 PM
Andy, you point is well taken and you may be 100% correct as we are talking about 9:5 compression vs 9:7 (but I really want that small compression gain).
Yeah DARTS would be a no brainer as they have a much thicker deck than the LS6 heads!
Old 11-05-2007, 09:14 PM
LASTLS1's Avatar
Those heads are thin as it is. Then if you ever have to do a clean up pass on them?? It stinks changing head gaskets and I think you could make more power with a little more timing than you could make from .2 of compression. JMO.
Old 11-05-2007, 09:42 PM
Good point, and CHRIS at POWERHOUSE PERF. told me the exact same thing today! You are starting to convince me to stay with 64cc heads and 9:5 to 1 compression!
Old 11-05-2007, 09:47 PM
LS1Tech Co-Founder
Yeah not worth it they are fine.
Old 11-06-2007, 12:13 AM
Blownramair's Avatar
I run stock displacement ls6 heads... cnc port/ polished... ran 17# w/o any issues besides the gaskets popping once or twice this summer...
J
Old 11-06-2007, 09:00 AM
LS1Tech Co-Founder
That's a funny statement Jayson, if you think about it.
Old 11-06-2007, 02:13 PM
I agree as it is not my objective to pop heads gaskests once or twice a season!
Kind of shows I need to stay at 64cc and limit boost to 15lbs MAX!
Old 11-06-2007, 02:27 PM
HUNTER02SS's Avatar
You guy's are correct. The dart's are some of the thinnest deck's. They are still good head's for 700hp though,not much more.
Quick Reply: Has anyone run LS6 heads milled to 62cc and ran up to 15 lbs of boost?
