Just baught 00 Z28 a4
Whats up new to the forum. Just purchaced a 2000 z28 A4 with 54000 miles. Wondering what the best mods would be for an automatic. Long tubes cat back etc. I live in a town with alot of manual mustang and want to be ablew to hang off the line what can improve the automatics responce?
Lid, headers, and a tune are most peoples first mods. Lid and headers got my Z28 to consistent 12.8xs in the 1/4 mile.
LS1Tech Administrator
Received 1,486 Likes
Do this:
Round 1: Air lid, catback (or cutout if you need to save money).
Round 2: Higher stall torque converter, trans cooler, drag radials.
Round 3: Headers w/ ORY, LS6 intake, ported TB, dyno tune
Round 4: Suspension. Decide if you want better handling or better traction. Choose parts accordingly.
Round 5: Heads/cam package; dozens to choose from. Do TONS of research, and pick something that suits your needs well. Get an LS6 oil pump and a better timing chain at the same time. Re-tune on the dyno.
Round 6: Built trans (FLP would be my choice), possibile re-stall of the TC, 12 bolt rear with 3.73ish gears, switch to slicks
Round 7: Power adder. Your choice, N2O or blower turbo. Likely need a cam swap as well.
Round 8: New shortblock. Iron or aluminum, your choice. Go low compression for blower/turbo. Or big cube/high compression for NA.
Tech Resident
I'd DEFINITELY get a built trans before a H/C package, unless you want your car to be unusable a few days after the install. Driveline components are ALWAYS more important than engine modifications. All the power in the world is worthless if the car can't move.
I have an '02 Z28. I have a lid, longtube headers, ORY, electric cutout, 3600 stall, 3.73 gears, and Nitto drag radials. With this setup i have yet to lose to a mustang(havn't raced a terminator though!), and have outlaunched every EVO and STI but 1. Do what suits you best, but with a similar setup, dont worry about the mustangs.
But I agree if it's a daily driver to build for strenght first, power second. If it's not a daily driver and you just want to race it, then you might as well push stuff till it breaks, assuming you have the means to get the car home from the track without a $500 towing bill.
Honestly, I'd never do anything more than bolt-ons for a daily driver. I've seen way too many people in my club build their daily drivers for racing and still try to rely *soley* on them for the daily commute. Even when using the best parts and doing it right, breakages are still more likely to happen with a high HP car that's driven hard, and if it's your only car, you're fucked. I'd never recommend building a monster for a daily driver, unless you have some other car to fall back on "just in case".
