View Full Version : Re-Sleeving LS4's for larger displacement
lsxregal
11-06-2007, 05:38 PM
I'm in the research stage of upgrading my '02 Regal with an LS4. What do you think of re-sleeving the block for larger pistons to get more power.
Area47
11-07-2007, 09:07 AM
anything that can be done in theory to the ls1-6 can be done on the ls4. well, except for crank changes.
Notime383
11-07-2007, 10:02 AM
Even cranks shouldn't be a problem given enough demand/dollars! I think a good topend Intake/heads/cam should produce some real good power (400-500HP) outta a 325 CID LSX! Does anyone have bore/stroke specs on a LS4? I tell ya a decent intake with a LS6 cam alone should do damage!
lsxregal
11-07-2007, 05:32 PM
I plan the standard LS2 4" bore with pistons to match. SLP has an L92 head/intake package for LS2's, and with a Livernois Motorsports Stage II cam, GM High Tech Performance did a dyno with this combo and got 546hp. Of course the trans will need to be built much stronger. I'm not sure which way to go in the cam b/c of the Active Fuel Management/DOD.
Nacho SS
11-07-2007, 06:15 PM
Technically, we are 323ci, not 325.
lsxregal
11-07-2007, 06:30 PM
Try this link for specs:
http://www.gmtuners.com/LS4/index.htm
eddiemoney
11-07-2007, 09:22 PM
Some pretty good pics there. Is that where you are getting your swap done?
lsxregal
11-07-2007, 10:48 PM
No, I wish I had the cash to have someone do it for me but I'm on my own. That's just a site I found during research.
Notime383
11-19-2007, 09:06 PM
Sorry! 323 not 325! I was hoping it was a 327 not 323!
06MonteSS
11-19-2007, 10:04 PM
I believe Notime is correct... we're 325 ci....
in addition to lsxregal's link, here's specs from GM as well:
Displacement (cu. in./liters) 325/5,328
Bore x stroke (in.) 3.78 x 3.62
Bore x stroke (mm) 96.0 x 92.0
Compression ratio 10.0:1
Block material cast-aluminum
Cylinder head material cast-aluminum
Valvetrain configuration OHV
Valves per cylinder 2
Ignition system coil-near-plug
Lifters hydraulic roller
Cam drive chain
Redline (RPM) 6000
Horsepower @ engine RPM 303 @ 5600
Torque (lb.-ft.) @ RPM 323 @ 4400
go here and enter 5.328 liters and hit the convert button...
http://www.csgnetwork.com/cubicinchlitercvt.html
http://www.4lo.com/calc/literstocid.htm
Nacho SS
11-20-2007, 12:42 AM
Cam drive chain
Redline (RPM) 6000
Well....I used that same calculator earlier and punched in 5.3L, getting 323cid...good find on the 5.328 liters lew :)!
lsxregal
11-24-2007, 01:03 AM
I know it's off subject but do the 5.3's have the same 6.098" connecting rod as the LS2's?
FIEROPHREK
11-24-2007, 09:22 PM
Yes the LS4's connecting rods are 6.098 inches long powdered metal rods. Not sure if they are the exact same p/n though. I imagine that GM would cut costs buy using the same parts that are common to differant engines though ie: rods, rockers, pushrods . . . .
