I like to know ... stroker BBC
hi guys ....
I like to know the proximal Wight for BBC 496 engine assembly
i hope to help me
This Complete Kit Contains:
Scat Series 9000 Pro Comp Lightweight Cast Crankshaft, 4.25" Stroke, 454 main, 2 piece Rear Main Seal. Kit is designed to internal balance (Will need to be balanced before assembly, may require heavy metal to balance.) This crank is approximately 67 lbs. PN: 9-454-4250-6385
Scat Premium 4340 Forged 6.385" I-beam Connecting Rods with ARP 7/16" 8740 Capscrew Fastners, Floating Pin, 2-ICR-6385-7/16
JE SRP Forged Pistons, PN: 212157, 4.310 bore - These pistons are +.060 bore (Other sizes available, please inquire) estimated compression is 10.2:1 w/ 118cc heads
Perfect Circle or Total Seal Plasma Moly Rings
Clevite 77 Performance 'P' 454 Main Bearings
Clevite 77 Performance 'P' 454 Rod Bearings
i hope to help me
Yeah pretty close. I mean as close as your gonna get with a dam boat anchor. BBC stuff is unbelievebly heavy so to drop that much weight switching heads and a intake is pretty good. Make a big difference for the car .
forged kit but the crank cast iron
the forged kit rang 2000 to 3000 $
