Header Install, How hard is it really
Old 11-08-2007, 12:19 PM
98camZ's Avatar
Default Header Install, How hard is it really
I need to know how hard is it to install headers on my 98 camaro Z28, the headersd are SLP Longtubes. do i need a lift or can i do it in my drive way with a jack and hand tools?
Old 11-08-2007, 12:24 PM
6THZ28's Avatar
it's much easier with a lift but sure it can be done in the driveway using jack stands...
Old 11-08-2007, 12:57 PM
Vrbas's Avatar
Did mine on jack stands with the help of a few friends. Not bad at all.
Garage is fine.
Old 11-08-2007, 03:20 PM
conde'strans's Avatar
You can sure do it on jack stands but it's gonna be a major pain in the *** cuz of clearance issues n everythin! Installation costs in a shop should run u about $100.
Old 11-08-2007, 03:28 PM
02NBMFormula's Avatar
it depends on how mechaniclly inclined you are. soak the bolts in break free the night before to help get them lose.
Old 11-08-2007, 03:30 PM
Pntbll309's Avatar
Um no...An install takes atleast 4 hours, whatever shop your going to that charges $25 an hour is amazing.Most shops charge a minimum of $350 from what I have seen...I did mine at home with some jack stands and had no problems what so ever. I would reccomend doing it yourself, learning about your car, and saving money for future mods.
Bad Blue WS6's Avatar
soaking is a big help
Old 11-08-2007, 03:33 PM
98Camarod's Avatar
Thats crazy low. You can expect to pay more than that. If you have the time and a few friends, get some beer and you'll be done in no time.
Old 11-08-2007, 04:26 PM
camross998's Avatar
dude it easy if you can change the spark plugs you can do the header install and all you just need any jack except the factory and sum jack stand bingo easy stuff (do it rigth the first time) oh and save your self the time and buy some good gasket because the ones that come with the header are crap easy stuff.
Old 11-08-2007, 04:38 PM
WS6 Rampage's Avatar
Location: The dirty taint of the country. ...Los Angeles
Hey,.. looky,.. its a fellow SLP bitch!! I have SLP LTs also. Honestly bro,.. with those LTs,.. take it to a shop. Even on a lift I was close to becoming homicidal put'n those suckers in.
Save yourself the loss of sanity. Something about SLP LTs just makes em a pain and a half to install.
Old 11-08-2007, 04:40 PM
Formerly darynC-10/23/10
Daryn's Avatar
for a first timer it will usually take about 6 to 7 hours.
advice is to have a buddy help hold the headers up for you so you can bolt them up. un bolt the coil pack assy and take that off. spark plug wires spark plugs. and a good ole 10mm ratchet wrinch will work wonders in the back of that passenger side
Old 11-08-2007, 04:48 PM
Have you ever installed SLPs?!! Seriously,.. it's not like installing a set of Pacesetters!
My personal advise is to take it to a shop if you want to save yourself the headache OR buy a bottle of bourbon to keep you company! ...just my .02
Old 11-08-2007, 06:09 PM
98camZ's Avatar
ok ya my roommate that i never see is a mechanic at the local chevy dealership that i used to work at in sales and he also said that we could prolly do it in my rents garage, but he is just worried about breaking bolts off in the block, anyone seein that happening?
Old 11-08-2007, 06:15 PM
98Camarod's Avatar
I haven't had that happen yet. I'd say its alot more likely to strip the threads out of the aluminum than it woult be to break the bolt off. If you are talking about removal of the original bolts then just try and spray it down with some penatrating lube and let it soak. It's not too hard. You'll be glad that you did it once its done.
Old 11-08-2007, 06:45 PM
$350 for installation????? Well damn that's like almost another set of headers! Where do u live or what? That's how much it cost me for my TA a while back and also for my friend's vette who just got them about a month ago!
Old 11-08-2007, 06:51 PM
6THZ28's Avatar
$350 is a pretty average price.. doesn't matter what shop you go to here in Houston - they all charge around $350 avg. It's expensive no doubt but you save yourself time and headache letting someone else do it.. i'd GLADLY pay $100!!
Old 11-08-2007, 07:31 PM
Reject's Avatar
man i'm glade i had pacesetters. i took those bitches out in 45 minutes and put tehm back in at the same amount of time.
Old 11-08-2007, 09:54 PM
SladeX's Avatar
my header bolts came out without having to spray them, it was the y-pipe bolts that made me say f it and just break them.
Old 11-08-2007, 09:57 PM
Daryn's Avatar
ditto +1 . header bolts were fine . just where the manifold connects to the catalyst it was so rusted i was like F it and yanked it till the bolts / nuts broke
use some wd-40 on them instead of the header bolts
Old 11-10-2007, 10:01 AM
Camaro396's Avatar
damn where do they do them for 100????? ill drive to wherever! cheapest ive been quoted was 400.00! I think im gonna do them myself.
Quick Reply: Header Install, How hard is it really
