Help with clutch
Old 11-08-2007, 06:09 PM
1FST99Z's Avatar
Default Help with clutch
I am having problems with the clutch. the tranny feels notchy. the clutch pedal goes in nice and easy but when I try to put it in gear it is really tough. now we adjusted the clutch pedal by rotating the nut on and shaft to get the pedal a little higher. now the car will not start. it is acting like the neutral safety switch is not engaging. but I have never looked into this. what am I looking for. if not that then I dont know what else it could be.
thanks
Wesley
Old 11-09-2007, 03:35 PM
robertbartsch's Avatar
....bad slave cylinder or master?
Old 11-09-2007, 03:53 PM
LS1TECH Sponsor
Joey@Tick's Avatar
Sounds like a hydraulic problem. What brand of clutch?
Old 11-09-2007, 08:22 PM
1FST99Z's Avatar
McCloud is the clutch. all brand new slave and master 500 miles ago.
Old 11-11-2007, 05:43 PM
1FST99Z's Avatar
found out today that my starter went bad as well as the neutral safety switch. talk about weird timing for stuff to go bad.
thanks.
Wesley
Quick Reply: Help with clutch
