EPP's blower cam with 1.75 rocker arms?
Old 11-08-2007, 11:46 PM
Jimmy P's Avatar
Default EPP's blower cam with 1.75 rocker arms?
I found a set of Comp Cam type rocker arms that are custom made by a local shop, that claim these will work with my ETP 240 heads. I want to try them out, but the only downside is that they only come in 1.75's. I am using EPP's blower cam.
Will that extra .05 on the rocker arms negativily affect anyting? I am just curious if anyone else has used that blower cam with with a rocker arm that increased the lift. thanks
Jimmy
Old 11-09-2007, 05:20 AM
TT-TECH Veteran
Inspector12's Avatar
Well it will also increase your ramp rate also, but I don't think it will be enough to hurt you, but you might call them and see what they think.
Old 11-09-2007, 10:49 AM
Jimmy P's Avatar
I asked Bob, but he said that they never personaly have used higher ratio rockers with their cam, so he wasn't sure what the outcome would be.
Old 11-09-2007, 12:35 PM
kp
kp's Avatar
I dont think it will affect much as long as your springs can handle the extra lift and the rockers arent super heavy. I havent used that exact cam but I have tried 1.8 rockers (or maybe 1.85, whatever the old SLP ones were) on other XER cams and they worked fine.
Quick Reply: EPP's blower cam with 1.75 rocker arms?
