Drag Racing Tech - 15's to clear stock brakes?
NJSPDER
11-09-2007, 09:00 PM
i know that the 3rd gen firebird fans will clear stock breaks, but they are only 7inches wide and i would like to find an option that won't pinch the tire and make it taller.
any suggestions?
-Thanks
chrismorales75
11-10-2007, 12:03 AM
Call me stupid but I didn't understand what you were asking too much, you're trying to put 15's on a LS1 stock front brake system?
Run bogarts or another rim with a little caliper grinding and spacer, most people run a 5/16". Some rims require less grinding than others.
I think some rims will actually fit without grinding, some of the bogarts, ask around I am not 100% sure.
NJSPDER
11-10-2007, 09:01 AM
i want to clear the factory rear brakes. for purposes of the project in question, there will be no grinding of anything. looking for 15 inch wheel, preferably a 15x8, that can be bolted right on with just a small spacer or nothing.
!5x7.5 centerline convo pros, I happen to have a pair for sale 5" backspace $250 plus shipping.
Pro Stock John
11-10-2007, 11:08 AM
15x7.5 Convo Pros.
The 15x9 (6.5) that we helped Centerline prototype would look better but you'll have to do a little grinding not much.
Matt D
11-10-2007, 05:49 PM
I have 15x7.5 Convo Pros with 26x8.5x15 ET Drags on them. No grinding or spacers. My time is in my signature. :cool:
VIPRETR2
11-10-2007, 06:00 PM
I think pretty much any Centerline wheel will fit. I run Warriors and never had to grind, also had some Auto Drags with no problems. I run 8.5s in the back.
NJSPDER
11-10-2007, 07:34 PM
what offset for 8.5's?
VIPRETR2
11-12-2007, 03:22 PM
5 inches
35th SS
11-12-2007, 11:30 PM
15x8.5 warriors here no spacers/grinding.15x10 weld draglites 7 1/2 spacing clears it2.
Pro Stock John
11-13-2007, 08:21 AM
15x8.5's stick out a bit.
vBulletin® v3.7.4, Copyright ©2000-2013, Jelsoft Enterprises Ltd.
Search Engine Optimization by
vBSEO 3.5.2
