f body alternator with a carb setup
Old 11-10-2007, 05:36 AM
DCx
DCx's Avatar
Default f body alternator with a carb setup
i had a question about using an F body alternator with a carb setup. will my alternator charge by hooking up the single wire to the back of it? or does it need more connections.
my 69 camaro was rewired with a painless 18 circuit gm muscle car harness. my current sbc is running a swap meet special 1 wire alt.
i purchased a new 105amp F body alternator when i bought all my F brackets. will it work?
**edit
i did some more searching... do i need to buy one of these?
http://cgi.ebay.com/ebaymotors/98-02...spagenameZWD1V
how exactly do i hook it up to a bulb? anyone got any pictures.
**edit
what is the clocking of the F body mounting locations? can i just get a 1 wire alt with the same mounting locations and use that? i know the rear bracket wont be used but will that cause any problems?
Old 11-10-2007, 07:00 AM
LS1MCSS's Avatar
You can use that connector and run a wire from 12v switched, through a 470ohm resister to the plug and it will charge.
Old 11-10-2007, 07:42 AM
DCx
DCx's Avatar
sweet. just like this then?
switched 12v ~~470ohm~~ebay plug to alt
and i still have my battery positive to the stud on the back of the alt?
Old 11-10-2007, 01:09 PM
Zedzag's Avatar
That's what I did and no problems yet.
Old 11-10-2007, 03:21 PM
DCx
DCx's Avatar
thank you. my head was spinning after reading all those posts. i didnt follow as to where the resistor was hooked up.
so the ebay pig tail connects to the B terminal on the alt?
looking at it from above when installed on the engine the 4 prongs are
ABCD
Old 01-31-2008, 02:48 PM
DCx
DCx's Avatar
oh i have no idea what i am doing. i picked up some 470 ohm 1/2 watt resistors from radio shack. how the heck do i wire it in? the resistors are so tiny! here is how i have it wired.
soldered resistor
and this is the plug to my alternator. is it the right one?
since my alternator pig tail is so small i crimped a spade connector to the end to i can disconnect it from the 12v wire lead.
Old 01-31-2008, 02:52 PM
Sawzall and Welder Mod
Whistler's Avatar
Right on the money!
Old 01-31-2008, 02:57 PM
LS1MCSS's Avatar
Be sure to put some heat shrink over the resistor and the rest of the bare spots where it connects.
Old 01-31-2008, 04:06 PM
DCx
DCx's Avatar
that was just a test piece for the pictures. the actual one i have soldered in isnt as nice... ill change it out since i practiced my soldering skills and let you all know how it works. out.
last time i had it running the amp gauge never moved off of 12v. even with just the key on, 12v. shouldent it be like 14v at idle?
Old 01-31-2008, 05:50 PM
Steve VanS's Avatar
Yep, wire it that way as in post 6 above, but a higher-wattage resistor would be good. The charge light wattage in an IP light would be a good guide.
Old 01-31-2008, 08:48 PM
DCx
DCx's Avatar
what size would you reccoomend? painless wiring has a harness for this style alternator that comes with a 82ohm 4watt resistor.
looking at the 470ohm 1/2 watt it looks mighty small. isnt the target voltage 5v? i tested my current wire and it still pulls 11.7~12v when tested.
when i had my old small block set up installed with a 100amp single wire the amp gauge would always dip to 11 then rev to 13 then dip again. do you think my optima red top was draining it?
Old 01-31-2008, 09:30 PM
sawzall wielding director
G-Body's Avatar
The 470 ohm 1/2 watt resistor is correct. You will end up with somewhere between 11 and 12 volts. What volt gauge are you using to measure the voltage?
Old 02-01-2008, 01:28 AM
DCx
DCx's Avatar
im using an old digital probe my dad had laying around in his tool box. i tested the wire just now and its sitting at 11.7v i tested another wire inside the car and its pulling 12.4v
here is a pic of the probe.
Old 02-01-2008, 11:48 PM
G-Body's Avatar
The easiest thing to do would be to have the alt tested at an autozone/advance/whatever that way you can be sure whether the problem is with the alt or the wiring. You have it wired correctly so I don`t really think that is the problem, I know its a new alternator, but the easiest way to diagnose a problem is to eliminate variables.
Old 02-02-2008, 01:55 AM
DCx
DCx's Avatar
its an ebay special... ill give it a shot.
Old 02-03-2008, 12:30 AM
DCx
DCx's Avatar
ok, i soldered in a new resistor. it didnt work. so i decided to pull one of the bulbs out of my autometer gauges ans wire that in series.
IT WORKED! the light bulb was on when i keyed the car, then went out when i started it. soon after 14amps on my gauge!
Quick Reply: f body alternator with a carb setup
