Weird question on ls7 clutch
Old 11-10-2007, 04:36 PM
tasilver's Avatar
Default Weird question on ls7 clutch
I have a ls7 clutch. It was professionaly installed with the drill mod. I have about 1500 miles on it. It has been very stiff but I got used to it. Now today it is light as feather. I am little worried because the clutch pedal did stick for second today. I have never used a replaced clutch and I know that clutchs need to broke in. So has anyone else running a ls7 had this happen, is it normal? It is dark out now but I am going to do the fluid flush from the sticky in this forum, just curious if anyone else has had the symtoms at the same time.Thanks for any help.
Old 11-10-2007, 06:08 PM
_JB_'s Avatar
During the short time I was able to drive my car, my clutch pedal got really light too, just out of no where within 200-300 miles. I never had any shifting problems though.
Old 11-10-2007, 06:25 PM
tasilver's Avatar
After reading the sticky, I hope I just need to flush my trans fluid. I am thinking mabe my headers are heating up the fluid. I won't know till tomorrow when I change the fluid. Just checking with everyone to know if there is anything else it could be. I did just install my LS6 intake today again, (had to replace the oil sensor )
Old 11-10-2007, 10:44 PM
00T\A's Avatar
Hmm i only have 150 miles on mine and it feels the same with the exception of not engaging so close to the floor quite a bit closer than my ls6.
I think i really broke it in tonight coudn't wait any longer
I also changed master & slave and used valvoline high temp fluid and no drill mod.
So far i'm loving mine.
Old 11-11-2007, 12:30 PM
tasilver's Avatar
It was my fluid I am sure. I spent a hour and used a bottle and a 1/4 of high temp syn brake fluid. It is clear now but it was jet black. At first I did not think it would ever clear up.
Old 11-11-2007, 12:48 PM
01FbTaWs6's Avatar
yeah, if the fluid was black, chances are it neede changed :-)
Old 11-11-2007, 07:12 PM
DVS99TRANS's Avatar
Mine was stiffer at first then fells better than stock now. Took mine about 1200-1300 miles though, babied it for a while after just getting my tranny back from Six Speed. Just in case, and a little overkill
Old 11-12-2007, 03:12 PM
BIG_MIKE2005's Avatar
My peadl pressure has always been the same. My fluid was black also & now has high temp. fluid. I also swapped out my slave for a newer one. I'm still on my stock master with 109k on the clock & it works just fine.
Quick Reply: Weird question on ls7 clutch
