Tricks and Mods question?
I am getting ready to install a new clutch in my GTO. Is there any mods or tricks that I should do while the trans is out?.... What all should I replace?... What is everybody else doing??? My car has 13000 miles on it. My mods are in my sig, and I am also installing a Nitro Daves plate kit... Any help would be appreciated!
If you are going to resurface ths stock flywheel use a Blanchard Grinder and measure how much you take off so that you can add that back in with a shim behind the slave. (FWIW I wouldn't go more than .030" on a stock flywheel)
