Need new window motor? Ebay?
Old 11-10-2007, 10:36 PM
Jglisson's Avatar
Default Need new window motor? Ebay?
I have a dying driver's window motor I believe. I found replacement window motors on Ebay for around $15. That is awfully cheap. Has anyone bought one of these off of Ebay? They can't be much worse than the factory motors.
Old 11-11-2007, 12:13 AM
SparkyJJO's Avatar
I got mine from ebay. It was a set actually, saving the one for when my passenger window motor fails (it is a bit weak but not dead yet, and don't feel like ripping the door apart to get to it). The one I put in the driver side works fine. A little noisier perhaps than the stock one in the passenger side, but not bad. Of course, that could also be due to it moving so much faster
Old 11-13-2007, 01:21 PM
thunderdan74's Avatar
I got a motor from ebay. It died in about a year. Then I replaced both with ones from Advance for about $50 each. It's been 2 years and their still going strong. The stock ones never worked this good.
Old 11-13-2007, 03:28 PM
Chase22's Avatar
I bought one on eBay for 15-20 dollars and it died within 2 weeks And it is a pain in the *** to install
Old 11-13-2007, 03:37 PM
chavez885's Avatar
Buy one locally at autozone or something. That way if it dies again you can take it back.
2001NBMZ28's Avatar
I bought two new ones (cheap) off an ebay store, one for me and one for a friend - box I handed him worked fine, mine was noisey from day one. If it was from auto zone and bad I could've brought it right back while I still had the door panel off. I'd get one locally with a lifetime warranty.
Old 11-13-2007, 03:43 PM
MJK
MJK's Avatar
X2!!!
Old 11-14-2007, 12:15 AM
02WS6_TA's Avatar
I bought one a while back off of a store on ebay. Really no noise that I can't put up with and it works fine. It has been in there for 4-5 months now. Little noise is better than a window that doesn't work.
Old 11-14-2007, 12:48 AM
chipabba's Avatar
Get the one from Siemens. I've gone through several and that one by far is the best. Swapping out the window motor is not something I want to do more than once...........
Old 11-14-2007, 12:54 AM
2MuchRiceMakesMeSick's Avatar
Ive seen the best luck with simmens
Old 11-14-2007, 10:01 AM
1BadAzzWS6's Avatar
I've replaced both my window motors and each time I bought them from Autozone. Can't bea the price or the warranty.
