1/8 times at the TRACK
Old 11-11-2007, 01:31 AM
Tulicy727's Avatar
Exclamation 1/8 times at the TRACK
Last week got an 98 trans am.. n i ran a 9.1...shud i be runnin better or any sugestions on y im not running harder..... besides da fact i spin tire nasty
Old 11-11-2007, 02:16 AM
Roarin_8's Avatar
Car should be in the mid to high 8s, where are you located at and what was your 60'?
Old 11-11-2007, 09:35 AM
Tulicy727's Avatar
my 60's were round 2.2-2.3...my top end speeds are round 77-81 but i can only get like 9.2 lowest....???
Old 11-11-2007, 09:39 AM
S1LV3R's Avatar
my '98 ran 8.8's @ 82. It was a 6 spd. I think an auto maybe a little quicker than that.
Old 11-11-2007, 11:06 PM
scites's Avatar
BONE SROCK MY 00 TRANS AM a4 RAN 8.9'S ...SPINNING ALL DAY..2.4 TO 2.6 60FT TIMES..FULL BOLT ONS WILL PUT YOU IN TO THE HIGH 7'S
Old 11-11-2007, 11:31 PM
Roarin_8's Avatar
77mph? Like I asked before, where are you located at? Sounds like high elevation. Also, auto or manual? Get the 60' down to 2.0-2.1 and you'll get your high 8.
Old 11-12-2007, 03:57 AM
95 Z28's Avatar
8.4 @ 86 off of a soft 2.0 60' ...I think my best MPH was like 87.5 or something like that.
Old 11-12-2007, 04:43 AM
odarabla's Avatar
I have a 2002 A4 with all bolt ons and a PTC 3500 stall converter. I ran a 8.0 @ 86.22 mph with a 1.74 60ft. This was done on Micky Thompson ET Streets DR's.. I hooked very hard. My 1/4 mile time was a 12.6 @ 108
Old 11-13-2007, 07:30 PM
BriancWS6's Avatar
Back in 03, my previous car, 01 TA a4, while stock, went 8.40s after I got the feel for it. I remember the first time ever down the track it went 8.72.
My current car (02 m6) went 8.40s as well while stock.
Your 60ft is killing you, get it down and you'll pick up and be closer to where you should be.
Old 11-13-2007, 07:40 PM
95 Z28's Avatar
Another thing...learning to launch a car on street tires is difficult. I'd suggest picking up a pair of Nitto DR's for the car, it'll make the learning curve of launching much easier IMO. I think that will also bring your trap speed up a little bit, as I suffered from the same low trap as you did back when I was on street tires. For instance, my car moved like a full bolt on M6 car should from a roll, but only trapped a best of 107 at the time. Put DR's on, which allowed me to actually accelerate through my first and second gear instead of blowing the tires off, and increased my traps to a consistent 110-111.
Old 11-13-2007, 07:43 PM
Candyredz28's Avatar
I seen a 00 SS running 9.1-9.5 and I seen a 94 Z28 run 9.3 stock so it all depends
Old 11-13-2007, 08:00 PM
speedshifterNC's Avatar
you should be atleast high 8's. I had a stock 88 Iroc 305!!! 5spd with 3.73 on street tires ran a 9.1.
Old 11-13-2007, 10:54 PM
Tulicy727's Avatar
any suggestions on rear tires 2 get dat i can use for racin and for street.
Old 11-13-2007, 11:20 PM
95 Z28's Avatar
I'd say Nitto 555R drag radials. They're pretty cheap too for how well they perform.
Old 11-14-2007, 08:43 AM
BriancWS6's Avatar
Yeah, Nittos are the most streetable of the drag radials. At your power level in an auto, traction should be no problem with them. I pulled 1.6 60fts with Nittos in my a4 car with the stock suspension.
Old 11-14-2007, 09:30 AM
colby72olds's Avatar
I ran a 8.7 stock and I don't remember 60' or mph. Should be a lot better than a 9.1.
Old 11-14-2007, 10:02 AM
Black_Bird's Avatar
Haha.
Old 11-14-2007, 10:06 AM
bjamick's Avatar
Here in bama on my first pass bone stock in a 105k miles 99 TA. I ran an 8.74 @ 84mph and then that was the only pass i made .
Old 12-04-2007, 05:42 PM
blown03mustang's Avatar
no way...my stock 03 mustang pulled an 8.7 all night long on street tires. you should be low 8s. 8.4 or less if you can get those 60s down.
Old 12-04-2007, 11:05 PM
Roarin_8's Avatar
I said mid to high 8s because his mph is a bit low. I'm guessing that he's at high altitude and most likely an auto which has less aggressive gearing than your stang.
