LS1 Transmission Question!
Old 11-11-2007, 10:49 AM
FirstOrLast's Avatar
Default LS1 Transmission Question!
I have a 2000 Z28 6 speed. My second gear is gone, it wont even go in, and right now I am just trying to find something cheap just to get me by until I can rebuild my messed up trans. I am just wondering what different manual transmissions would work for this car? thanks for any help that is provided.
Old 11-11-2007, 02:06 PM
Will a Borg Warner T56 transmission work for my car? thanks for any help.
Old 11-11-2007, 02:11 PM
Kleeborp the Moderator™
MeentSS02's Avatar
Borg Warner is now Tremec, and the T-56 is what you already have, so if you can source another, it will drop right in (for the most part).
Old 11-11-2007, 04:05 PM
LS1_Fonzie's Avatar
Be sure it is a 98-02 T56, if I remember correctly they are different from the T56 in the LT1.
Old 11-11-2007, 08:46 PM
KillerZO6's Avatar
the bell houseing and input shaft is differnt
Old 11-11-2007, 11:24 PM
What spline is the input shaft for the ls1 transmission? Is the 98-02 t56 the only manual transmission that will work?
Old 11-12-2007, 09:22 AM
ls1 joe's Avatar
Yes without having to change front plates, bellhousings or input shafts. The LS1 T56 98-02 is the only thing that will drop right in without changing anything. That is the only manual that will bolt up without any changes and I am sure that is the only manual that will bolt up period.
Amber
Old 11-12-2007, 10:58 PM
Can you take a new t56 and a older one and swap some parts so as the old one will work? thanks.
Old 11-13-2007, 09:53 PM
KillerZO6's Avatar
yes you can
Old 11-13-2007, 10:03 PM
Ok, so I put my newer bellhousing on the older transmission and then I swap the input shafts and that is all? Anybody got a link where I could see the input shaft being changed? thanks.
Old 11-14-2007, 04:19 PM
Old 11-14-2007, 09:03 PM
KillerZO6's Avatar
just look up "how to rebuild t56 94-97 and 98-02" and u can see what is different
